Top of radiator coolant leak
Results 1 to 8 of 8
This is a discussion on Top of radiator coolant leak within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Just pulled over to check engine because I smelled coolant. Apparently I'm blowing steamy coolant out of a crack in ...
    May 2009
    Just pulled over to check engine because I smelled coolant. Apparently I'm blowing steamy coolant out of a crack in the plastic above the radiator near where the top hose connects. Any causes / solutions I should know about?
    Could there be something causing excessive pressure?
    Could this be a jb weld situation?
    New radiator?
    Taking her home now...
    Thanks for any input
    Nov 2009
    You just got the infamous OEM radiator crack. You are going to need to replace it. There are threads on this so do a little search and you will find a ton of info. My suggestion is to replace your t-stat and hoses when you swap radiators. Good luck. If you need to drive it home don't let your rev's go higher than 1.5k. I limped my car home like this and I did not lose any coolant. Last thing don't let your car overheat.
    May 2009
    Thanks for the speedy reply. Ugh that sucks. Well, off to spend $300 it looks like. And it won't even add hp or look cool.. lol.
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by jak461 View Post
    If your short on cash I have seen people patch is temporarily with JB weld...however no guarantees... eventually you will need a new unit as mentioned...
    Apr 2004
    Southeastern PA
    Get an all aluminum radiator as a replacement if you can. I've had trouble with a few other plastic / aluminum radiators in previous cars.
    Mods & Pics
    Nov 2009
    My Mishimoto radiator looks cool.
    Registered User T.J.'s Avatar
    Oct 2002
    on a boat...
    Yep. Very common failure.
    Don't spend $300. Check ebay for aluminum radiators. Cheap, increases coolant capacity and looks cool.
    200,000 mile club.
    Old Irish adage: "Do not resent growing old. Many are denied the privilege."
    May 2009
    Nice!
    Thanks again all for the input.
    I luckily found a new Mishimoto for a reasonable price that -of course- i'm now looking forward to installing.
    +1 to all yall
