AC removal
Results 1 to 12 of 12
This is a discussion on AC removal within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ok so i pulled out my ac compressor yesterday and gonna take out the condenser out tomorrow. i took my ...
    Registered User phatmike0704's Avatar
    May 2007
    AC removal
    ok so i pulled out my ac compressor yesterday and gonna take out the condenser out tomorrow. i took my car out after i removed the compresser for a ride and i realized the fan doesnt work when the car is at a stop, only moving. i even put it on the 4th setting and still didnt feel nothing at a stop. does removing the AC compressor affect the fan or did i do somethin wrong?
    oh and do i leave those holes unplugged wher it connects to the wall?
    Aug 2008
    Kennett Square, Pennsylvania
    I'm assuming your talking about the blower motor not the cooling/sub fans? That is where the AC lines connect to the Evaporator/ Expansion Valve....Personally if your removing the entire AC system why not remove the Evaporator/Expansion Valve also? than you can just ram rubber dummy plugs into the firewall.........
    May 2007
    well removed everything but left condenser on for protection of radiator. now i noticed the the heater doesnt function right. it stops working and sometimes works for 5 minutes, anyone know whats wrong?
    Aug 2008
    Quote Originally Posted by phatmike0704 View Post
    Hmm need a little more information, so your saying the blower motor will operate properly however the incoming air isnt always heated? even when selected to the hot position.......
    Jan 2005
    Eh, whaaaaa?
    Sounds like an air bubble in the cooling system, but that shouldn't have been caused by removing anything in the AC system, unless you removed a coolant line.
    Cody
    May 2007
    the other way around. the heat works fine, its the blower thats the problem. the fan shuts off sometimes. and no coolant lines removed, only ac lines
    Aug 2008
    Does it only not work on one setting? or is it like when your driving along and it just shuts off altogether?
    May 2007
    it works on all settings just shuts off at random times
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    Do you have the automatic climate control system or the standard ac/heater/fan controls? (not sure what year/model car you have)
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    May 2007
    04 wrx, standard heat. i finally found the problem!!!!!! i took out the AC fuse and never put it back in. pushed her back in, tested it, worked. tested it some more at different times and works.
    Dec 2006
    Philly/DE area
    ahhh! glad to see it was a simple fix.
    Aug 2008
    AH relief feels good doesnt it? , doesnt look like you have to break the bank for this one
