Results 1 to 4 of 4
This is a discussion on High Boost 18.3 + within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello, Im running a vf34 with all the necessary mods. I lately pluged in the access port to read my ...
    Registered User zeus32's Avatar
    Mar 2010
    Albuquerque NM
    High Boost 18.3 +
    Hello, Im running a vf34 with all the necessary mods. I lately pluged in the access port to read my live boost and it maxed out at 18.3 so im guessing its a little higher than that. My gauge shows it hitting 24lbs but its not that accurate. What would cause this high boost and how can i fix it.
    Registered User Dos-fivewagon's Avatar
    Dec 2009
    portland
    Need way more info to help with problem. What mods exactly? What stg. map and which one, pro tune? etc.
    One industrial accident away from financial freedom!
    Blobeye Syndicate #215
    Moderator Donkey's Avatar
    Da boonies
    2002 FORESTER S
    1998 FORESTER S
    Aug 2009
    Canada/Ethiopia/Madagascar
    Donkey's FAQ is a great read.
    That said, if you've followed Cobb's map requirements to the letter, read the map notes. Assuming you're a bug eye, and reading the notes for the VF34 91oct map your target is 16.5 +/- 0.7 psi.
    I'm making too many assumptions though.
    Edit: I read VF39...fixed reference above.
    ...Rob.
    [my photos]
