Page 1 of 3 123 LastLast
Results 1 to 15 of 35
This is a discussion on evap canister removal ??? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just purchased a 96 impreza 2dr coupe 5spd awd for 0. I know, its not a wrx/sti but I'm ...
    Mar 2010
    I just purchased a 96 impreza 2dr coupe 5spd awd for $500. I know, its not a wrx/sti but I'm building it to be a race car. My question's are, how can i remove the evap canister under the rear bumper and still run the car? are there any perks or down falls from this? I don't care about emissions. Mike.
    Jul 2008
    San Antonio
    It's a fuel evap .... Keep it...
    Pics of the car ?
    Paul
    2007 MS3
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Mar 2010
    some pic's not pretty, but going to be fun to build up. Really want to remove the fuel evap canister!!!
    Quote Originally Posted by subinut24 View Post
    Why?
    Oct 2008
    ACT
    Quote Originally Posted by sd_gr View Post
    why?
    +1
    Jul 2008
    San Antonio
    Weight reduction? 3 lbs? (better off switching to light lugs) I can't find a logical reason at all.
    You should start a progress thread on your build.
    Paul
    2007 MS3
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by pzr2874 View Post
    +1 ^ ....Also in 96 ( unless its a 1.8 FWD Cali. spec model) if its a USDM model the canister should be behind the P/S headlight housing next to the ABS/HCU...
    Mar 2010
    seriously, to those of you that have responded, your'e a bunch a f*****g idiots, weight reduction, haha, yeah I'm serious about losing 3lbs. All I asked was if someone could tell me how to remove the canister and still run the car, and I get smart a** remarks, if you dont have helpful input don't say anything. I know enough about subaru's I know that the canister is under the rear bumper on the passenger side, US model, like I have the f*****g money to waste on a '96 cali. version 1.8. in VT. Like I said, if you dont have anything helpful to say, don't say anything!!!
    Jan 2005
    Eh, whaaaaa?
    They ARE attempting to help you, they want to know your reasonings behind removing it. It's a standard part on every Subaru and has no bearing on performance, nor does it decrease performance in any way. Why are you so adament, and defenseive, about wanting to remove it? Answer that and maybe someone will give you the answer you want.
    Cody
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    Id probably take a deep breath and relax, the person who your screaming at in my best knowledge is a certified subaru technician and knows his stuff. Cali models can be all over doesnt matter if your in VT.
    Lead Wrench @ WTF Tuning, LLC
    Jul 2004
    Seattle, WA
    Sounds like a good price. Even if it's not in perfect shape, you should post some pics.
    Locate and remove the canister. There is a line feeding from the gas tank that connects in to the canister, do not block off the end of this line. The gas tank requires the ability to take in and expel air though this line.
    I'm not sure if this line is hard or soft, but make sure it's attached to something firm and that it's out of direct path of stuff getting in it.
    The following PDF specifies it's a Toyota canister spec, but the system is the same on Subaru's.
    http://www.autoshop101.com/forms/h62.pdf
    Perks
    1. Your car will lose 3lbs in an area of the car that could stand to loose some weight. Provided it is located in the engine bay.
    Down Falls
    1. Check engine light will come on. The ODB-II spec and US Federal Law requires the Evap canister to be installed, and functional on street driven vehicles. Some racing organizations require the EVAP system working (some AutoX classes come to mind).
    2. You may be able to have a ECU tuner disable this code, but it's going to cost you a tune. There is not a free/cheap way to tunes your 1996 2.2L NA ECU (that I know of at least)
    3. Road debris can enter the tube causing issues.
    4. Fuel sitting in the tank can freely evaporate to the atmosphere.
    5. Evaporated Gasoline under the sunlight produces photochemical smog.
    6. Here's some information about why the Evap system is important.
    Gasoline - Wikipedia, the free encyclopedia
    Besides lowering the volatility of the fuel, other means of controlling the emission of unburned hydrocarbons, for environmental concerns, exist and are used. All vehicles sold in the United States (since at least the 1980s, probably the 1970s or earlier) are required to have a fuel evaporative control system (called an EVAP system in automotive jargon) which collects expanding fuel vapor from the fuel tank in a charcoal-lined canister while the engine is stopped and then releases the collected vapors (through a "purge valve") into the engine intake for burning when the engine is running (usually only after it has reached normal operating temperature.) The fuel evaporative control system is also required to include a gasketed filling cap which seals the fueling inlet to prevent vapors from escaping directly from the tank through it. Modern vehicles with OBD-II emissions control systems will turn on the MIL (Malfunction Indicator Light, a.k.a. "check engine" light) if it is detected that the gas cap is missing or loose and so not sealing. (The general purpose of this light is to indicate when any of the emissions controls are not working properly.)"]Besides lowering the volatility of the fuel, other means of controlling the emission of unburned hydrocarbons, for environmental concerns, exist and are used. All vehicles sold in the United States (since at least the 1980s, probably the 1970s or earlier) are required to have a fuel evaporative control system (called an EVAP system in automotive jargon) which collects expanding fuel vapor from the fuel tank in a charcoal-lined canister while the engine is stopped and then releases the collected vapors (through a "purge valve") into the engine intake for burning when the engine is running (usually only after it has reached normal operating temperature.) The fuel evaporative control system is also required to include a gasketed filling cap which seals the fueling inlet to prevent vapors from escaping directly from the tank through it. Modern vehicles with OBD-II emissions control systems will turn on the MIL (Malfunction Indicator Light, a.k.a. "check engine" light) if it is detected that the gas cap is missing or loose and so not sealing. (The general purpose of this light is to indicate when any of the emissions controls are not working properly.)
    That's fine, there are lots of folks running around in turbo Subaru's without catalytic converters.
    However, changing the exhaust is a well thought out, highly regarded modification, with very few drawbacks.
    Is 3lbs really worth the hassle that goes with removing this?
    Last edited by SeattleJeremy; 03-17-2010 at 10:31 PM. Reason: It's a 2.2L not a 2.0L, my bad.
    Jul 2004
    Seattle, WA
    If you really want to put your car on a diet look at "AnorexicSTI's" car for inspiration. He's obsessed with making his car as light as possible.
    The first page lists every item he's removed from the car. The Evap canister is not on the list.
    AnorexicSTI - 05 STI Lightweight w/ "full interior" - 2660lbs - 62 lbs to 2598! - IWSTI.com: Subaru WRX STI Forums
    Jul 2008
    San Antonio
    Tool
    Paul
    2007 MS3
    Oct 2002
    The Old Folks Home
    No one has been rude to you here. Consider this a verbal warning to lighten up; we frown upon both personal attacks and dodging the swear filter to use the f-word in our tech forums.
    --Ray
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon
    Mar 2010
    oh no did I f*****g offend you, deal with it, life isnt a box of chocolates, people are rude everyday, it's what makes us different. You wanna block me from the site, go ahead, I come on here to ask experienced techs/enthusiasts and I get ragged on about my intentions, wrong person to be warning!
