Results 1 to 4 of 4
This is a discussion on Help with click noise from spark plug within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I changed my plugs today now I get a slight clicking noise from the cylinder on the right side of ...
    Feb 2010
    Cherry Hill, NJ
    I changed my plugs today now I get a slight clicking noise from the cylinder on the right side of the motor closest to the firewall. When I undo the coil to that cylinder it goes away and when I step on the gas it gets louder. I pulled the plug out and its fine. Suggestions?
    Registered User Bahamabob's Avatar
    May 2005
    Bridgewater, Ma
    You might have arcing on the insulator from anti seize compound. pull the plug and clean it. Spray the inside of the boot on ignitor with maf cleaner or alky . Keep it clean and reinstall. Good luck
    Jul 2008
    San Antonio
    Quote Originally Posted by infiniteboost View Post
    Did you disconnect the battery when doing the install ?
    Paul
    2007 MS3
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Feb 2010
    Cherry Hill, NJ
    Quote Originally Posted by pzr2874 View Post
    Yes. Turned out the coil was bad. Put a new coil on and no problems.
