Results 1 to 15 of 30
This is a discussion on gaping iridium plugs??? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i just bought NGK iridium spark plugs and put them in my 2006 wrx TR. does anyone know if iridium ...
    Registered User drew_ladue's Avatar
    Mar 2010
    SILVERDALE WA
    i just bought NGK iridium spark plugs and put them in my 2006 wrx TR. does anyone know if iridium spark plugs need to be gaped?the guys at the autoo shop said they didnt need to be. now my wrx is bogging out and sounding like its backfiring anytime i floor it. it doesn't do it when i moderately accelerate and the turbo still spools up. the only things i moved to put the spark plugs in was my perrin intake and the battery. i made sure to tighten down the plugs and the coil packs.the only mods i have are the perrin intake and hks exhaust. anybody have any idea what might be the problem?
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    you dont gap iridium. Kinda like you dont google chuck norris.
    Your positive you got all connections correct, all coil packs on correct and in correct locations?
    Lead Wrench @ WTF Tuning, LLC
    Mar 2010
    SILVERDALE WA
    yea. 2 of the plugs i took out were really loose actually. do spark plugs need to be "broken in"?
    Dec 2004
    Your Mommas
    Nope. Lightning bolts spark until they cant spark anymore.
    Mar 2010
    SILVERDALE WA
    haha. i'll agree with that statement. im just gonna have to take it to a shop tomarrow and see how much money they wanna rob me for.
    Dec 2003
    Dallas, TX / Sterling, VA
    HKS catback or HKS turboback?
    Dec 2004
    Your Mommas
    Quote Originally Posted by brfatal View Post
    Is the new HKS downpipe catted? I havent seen a new one yet, I heard they did a redesign.
    Dec 2003
    Redesign? There have been 2 different HKS downpipes for a little while now if that's what you're thinking of.
    Dec 2004
    Your Mommas
    Last time I bought one (04) they had 1 design.. sorry..
    Anyway if your not running a cat this could be your issue.
    Mar 2010
    SILVERDALE WA
    im not sure which one it is. it was on my wrx when i bought it. and i dont think thats the problem cause it was working fine before i changed the plugs
    Dec 2003
    Iridiums come pre-gapped according to the model number your order, so if you got the right part, they should be ok out of the box. Attempting it will potentially ruin them.
    I asked if it was a turboback because being catless would explain the afterfires as well as driveability problems (along with that intake, which needs to be tuned for).
    Dec 2004
    Your Mommas
    well you disconnected your battery so the idle & air/fuel ratio had to relearn.. If you have a catless exhaust systems 06+ have had issues running catless. It may be the problem..
    The other issue may be... Do you have any CEL? I would suggest going out turning off all electrical items...
    Disconnect positive cable for 5 minutes
    Reconnect battery cable.
    Start car and let idle (no electrical items on, do not touch the throttle) for 10 minutes.
    Go drive, see if that helped.
    Mar 2010
    SILVERDALE WA
    k.i'll try that.my check engine light will blink 4 or 5 times if i let it bog out for a little. it doesnt come on if it just does it for a second or 2.but normal conditions is it is not on. the only electrical item i have is the radio. unluss you can think of anything else thats stock. how would i go about tuning my car?
    Jan 2010
    Ohio
    i mean it wouldn't hurt to take one plug out and make sure they are gapped correctly maybe they grabbed you the wrong box which im sure didn't happen. I believe factory specs on the wrx ask for .030
    2002 WRX--Stage 4
    Tuned by TurboXS
    Jul 2008
    San Antonio
    Quote Originally Posted by drew_ladue View Post
    One step at a time bud
    Paul
    2007 MS3
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
