How to Make a OBD2 Diagnose??
Results 1 to 5 of 5
This is a discussion on How to Make a OBD2 Diagnose?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello. I bought an ebay cheap obd2 usb interface, but my doubt is how is the right procedure to make ...
    Registered User FORESTERSTI's Avatar
    Feb 2010
    chile
    Hello.
    I bought an ebay cheap obd2 usb interface, but my doubt is how is the right procedure to make a diagnose and /or a code reset.
    There are a green test mode connectors and they get me confused
    Thanks for the help
    Dec 2003
    Dallas, TX / Sterling, VA
    You shouldn't need to use any connectors?
    Aug 2009
    Canada/Ethiopia/Madagascar
    You can pull codes without having to connect the test connectors; only the OBDII port itself.. Aside from having to hook them up when I reflashed my ECU I have no idea what they're for.
    I read/cleared a code just this morning, no test connector fiddling required.
    ...Rob.
    Feb 2010
    chile
    Thank you for the feedback.
    So, i presume the procedure is as follows
    Turn on the laptop
    opne the obd2 software
    conect usb to obd2
    turn on the ignition key engine on or off??
    read???
    Aug 2009
    Key to the on position should do the trick, engine doesn't have to be on.
    ...Rob.
