Results 1 to 4 of 4
This is a discussion on 2004 Impreza Starting Issues Help Please! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Thanks I'll try it today and get back....
    Mar 2010
    Aug 2008
    Kennett Square, Pennsylvania
    A shot from the hip... it does sound like the plunger in the little "neutral start switch" above the clutch pedal is sticking....Sometimes if you lube it a tad it might loosen things up..
    Registered User 68sprintb's Avatar
    Dec 2005
    Cupertino, CA
    Definitely sounds like the clutch switch sticking. They're pretty easy to get to, so if you can remember to make sure the transmission is in neutral before starting the car you can just bypass the switch entirely if it keeps acting up.
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / Scooby Sport New Age centre pipe & backbox
    Mar 2010
    You guys rule I'll try it today.
