HELP!!! WRX Engine Sounds
Results 1 to 6 of 6
This is a discussion on HELP!!! WRX Engine Sounds within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Long story short 02 WRX VF39 swap with 99k miles. Started with a coolant leak at the throttle body and ...
    Registered User wrx02blk's Avatar
    Jul 2007
    Minnesota
    Exclamation HELP!!! WRX Engine Sounds
    Long story short 02 WRX VF39 swap with 99k miles. Started with a coolant leak at the throttle body and then the car died and wouldn't start. Coolant leak was fixed. The first sound I'm unsure about is the tapping. It sounded to me like a bad tensioner so I did my 100k maintenance and replaced my waterpump and timing belt/tensioner. I also replaced my fuel filter. Put the car back together and it starts up now but makes two unknown noises, the tapping is still there and a screeching sound is now present. That's the second sound - screeching. The screeching wasn't there before the car died but is very loud now. This is a link to a video I posted on YouTube from my phone to help decipher my sounds and locate my problem(s)
    that's what I could think of but I will respond to any questions asap. Thanks in advance!
    YouTube - Wrx engine sounds
    Registered User vttk_mig69's Avatar
    Jan 2008
    Sheboygan, WI
    thats how mine sounded sry to be the bearer of bad news but that is a spun rod bearing im almost positve.
    yea just listend to the vid a few more times thats a spun rod bearing sry man.
    Jul 2007
    Minnesota
    Thanks for the quick response. Spun bearing was one of my guesses but my oil doesn't have any shavings in it so I was hoping that meant it wasn't a bearing.
    Jan 2008
    Sheboygan, WI
    well im pretty sure thats what it is. I also found out that on the piston that the rod had spun on the piston was also cracked and scored the cylnder wall and broke 2 of the piston rings. I just ended up buying a whole engine from a junk yard that had 12k on the motor.
    Well good luck in fixing it and again sry for the spun rod bearing.
    Feb 2010
    SL,UT
    yeah definitely sounds like something in your valvetrain.... if i were you id just look for a cheap new engine possibly on ebay cause if you were to rebuild it youd be looking at bout 3.5k just a guess though and you should be able to find a used engine for like 1.5k or so good luck man... ii found 1 for 1600 here is the link SUBURU WRX EJ20T TURBO ENGINE AND 5 SPEED TRANSMISSION : eBay Motors (item 260566628727 end time Apr-09-10 15:56:25 PDT)
    Hawk-Eye Alliance #801
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by 06scoobyrex View Post
    Old school JDM I like it...
