New Boost Gauge - Vacuum at IDLE?
Results 1 to 9 of 9
This is a discussion on New Boost Gauge - Vacuum at IDLE? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just got an SPT boost gauge installed and at idle, it reads about 18-20 inHg - is that the ...
    Registered User hieu1004's Avatar
    Mar 2010
    Washington
    I just got an SPT boost gauge installed and at idle, it reads about 18-20 inHg - is that the normal range?
    I know altitude/elevation can also affect the reading, but do accessories like the radio, etc also affect it?
    Thanks!
    Stink-eye Mob #1004
    2011 SSM STi 4-Door
    2010 OBP WRX Limited 5-Door
    2001 Lexus IS300
    2001 Honda Prelude SH
    1977 Honda CVCC
    Jan 2005
    Canada B.C.
    When the engine is healthy and working correctly , at idle the needle should be steady and within the range of 17 - 22 inHg
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
    Aug 2008
    Kennett Square, Pennsylvania
    Quote Originally Posted by hieu1004 View Post
    Thanks!
    As mentioned a steady reading of -17 to -22 in. at idle is normal...the only accessory that might affect it is one which ups your idle a tad such as switching on the AC or when the fans kick on however it only ups your idle by a few hundred RPM's if that so it shouldnt affect your engine vacuum my much if even at all...
    Mar 2010
    Washington
    That's good to know. Thanks for the replies, this is my first turbo car and so I am still learning.
    Stink-eye Mob #1004
    2011 SSM STi 4-Door
    2001 Lexus IS300
    1977 Honda CVCC
    Registered User Willard's Avatar
    Feb 2009
    Camarillo, CA
    All engines will have Vac at idle. If you hook a boost gauge to an N/A engine and mash the gas the needle will only go to 0 or near 0. On an F/I turbo or S/C engine the needle fly by 0 and get into positive manifold pressure, or boost, and stop at the wastegate or pulley setting. There are other variables but thats the basics of it.
    2011 Honda CR-Z EX
    Milano Red / Navigation / 6MT
    2009 WRX hatch premium SEM #52 Traded 7/28/11
    Kartboy STS & bushings // RedlineGoods Shifter & E-brake boots // Muffler delete pipe // Window tint //
    Registered User shello007's Avatar
    Nov 2008
    Newark, Delaware
    My Gauge's Erroneous reading
    My Gauge used to read 20 inHg. Then it went to 15. After uppipe install (maybe a month or two afterwards) it's idlng at 12 inHg. Please help. Is it a vacuum leak or a pressure difference on the exhaust?
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by shello007 View Post
    Probably a vacuum leak or a borked gauge.
    2002 FORESTER S
    1998 FORESTER S
    Mar 2010
    Washington
    ^^^^^ What he said. Check all hoses real carefully.
    Stink-eye Mob #1004
    2011 SSM STi 4-Door
    2001 Lexus IS300
    1977 Honda CVCC
    Jul 2010
    i just bought my 06 wrx and it has the mpa boost gauge on the steering column and i think i may be very much mistaken but at max boost its only reading .06 mpa and my understanding is it should be reading around the .08 - .09 range.... is this right or am i way off the mark?
