ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > General Maintenance, Troubleshooting & Accidents.
General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here!
Advertise On ClubWRX
Welcome to the ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums.
Welcome to the ClubWRX.net Subaru Impreza Enthusiast Site. ClubWRX.net is a forum based online community for people to hang out, have fun, and gain lot of valuable knowledge about anything related to the WRX. You can learn more about ClubWRX.net here.
You are currently viewing our boards as a guest which gives you limited access to view most discussions, articles and access our other FREE features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload your own photos and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact support.
(Registered Users of this site do not see this ad.)
Reply
Thread Tools Rate Thread Display Modes
Old 03-11-2010, 04:05 PM   #16
Donkey
Reincarnated Stalin of WRX tuning
Donkey's Avatar
My bet is the car is possibly detonating and the ECU is pulling boost and timing to save the motor. The actuator doesn't just "pop" open at the preset level. It will slowly will open and should be completely open by the preset level. A 7psi actuator will start to crack open around 3-4 psi.
__________________
My Mods My Pics
Donkey is offline   Reply With Quote
Old 03-11-2010, 04:43 PM   #17
mycologist
The Mushroom Moderator
mycologist's Avatar
Quote:
I was kind of wondering about that but something I read made it seem that that was the definition of "preset". It still should equilibrate to 7psi on the car though. I still would wager that the WGDC is pegged at 100%. I would still fix it even if something else is wrong.
__________________
mycologist is offline   Reply With Quote
Old 03-11-2010, 05:26 PM   #18
mycologist
mycologist's Avatar
Just a sanity check, it does cause problems commonly on the older cars, we probably just don't see it much yet:
Scoobypedia | Trusted knowledge for everything Subaru | Knowledge / Boost Related Issues
__________________
Old 03-12-2010, 11:49 AM   #19
Myzkoo
Okay, but if detonation was my problem would it just limit the boost and timing without trowing a CEL or att some point miss and rattle a little? The engine is running smooth..
Hmm.. well ive obtained a acutator from a friend now, a brand new one actually, with an adjustable arm. Im going to pull my one off and then compare these two with compressed air connected before i start working with the new one.
I will have to fabricate a bracket to fit this new one but that will not be a big problem i think.
Will post updates within 24 hours.
Myzkoo is offline   Reply With Quote
Old 03-12-2010, 12:11 PM   #20
mycologist
mycologist's Avatar
I heard mine rattle when I had an inlet leak - IAM was only dropped to 12 and it wasn't pulling boost yet.
Just so you know though, we are all taking a bit of a blind shot without the logs. Hope this wastegate isn't a waste of your time .... (then again driving 6 hours only to find out you need to do this then come back would also be a big waste).
__________________
Old 03-12-2010, 12:22 PM   #21
Myzkoo
Ok, yea i know but it feels like that i should be doing this. Its not that much of work. Think it's alot easier than removing the intercooler and reinstalling that piece.
Will be looking into logging the car if i cant sort this out this weekend..
Old 03-13-2010, 04:52 PM   #22
Myzkoo
A little update.
Unbolted my acutator from the turbo and putted it next to the new one on the table. i compared those two with compressed air and it was exactly the same strength in both.
Fabricated a bracket and installed the new one in the car, had the arm adjusted so it was the same lenght as the old one.
Hooked up a clean vac-line from the compressor housing to the acutator, had it for a spin and same boost as before achived..0,3 bar.
Since the new one was adjustable i shortened the arm like 5mm. Had to pull a little harder to get the locker in. Test drove.. Same boost, 0,3 bar. Then i shortened it another 7 mm (arm is totaly 12mm shorter than the old wastegate now) and had to pull it even harder to get it on. But guess what.. Same boost..
How is this possible? The ecu cant do anything in some way to "release" pressure as far as i know. This is 100% mecanical now.
Will run the vac-lines as they should be tomorrow and see if it hits 0,7 as before with the solenoid. Will pull the downpipe down too.
Old 03-13-2010, 08:25 PM   #23
mycologist
mycologist's Avatar
Quote:
Originally Posted by Myzkoo View Post
A little update.
It would seem now that your boost gauge is not working correctly. I would be hesitant to hook it all back up with that much pretension if you aren't 100% confident in the gauge as you could have bad boost spiking or overboost.
__________________
Old 03-14-2010, 12:32 PM   #24
Myzkoo
It is definitly not over boosting or spiking, runns like a N/A car :P
Old 03-14-2010, 12:42 PM   #25
mycologist
mycologist's Avatar
Well dang. When I adjusted my arm just a couple turns (threads) is good for ~ 1 PSI.
Time to inspect the turbo itself and or get a log.
__________________
Old 03-20-2010, 10:37 AM   #26
Myzkoo
Havent had any time for the car for the past few days. But today i hooked up all the vac-lines as they should be with the boost solenoid connected.
The high-tension adjustment on the acutator is still there.
And i could see that boost peaks at 1.05 bar (almost 1.1 bar). But its only for like a split second then it drops back to 0.6-0.7
Will pull the dp down on monday or maybe tuesday.
Will make an $1000 order from extremepsi.com tonight too
Old 03-22-2010, 08:51 AM   #27
mycologist
mycologist's Avatar
Bewildering - I'm very interested to hear what you find when you look at the flapper. Almost sounds like something is stuck in there.
__________________
Old 04-01-2010, 02:07 PM   #28
Myzkoo
Problem still not solved.
But managed to finally log the ecu with a diagnostic tool called AUTO-COM that i found at a local shop. Was able to log 3 minutes of driving. And one thing i noticed was that the intake pressure (i guess that this is the pressure measured from the map-sensor) was showing 2.55 bar while my boost gauge showed 1.0 bar, wich is max boost i can reach with this adjustable wastegate. I know that the map reads the atmospheric pressure to but its still like 1.55 bars of boost messured?
So i borrowed my friends map-sensor but still got the same readings on from the ecu.
Is this ok? Shouldnt the mapsensor be reading the same pressure as my boost gauge?
Old 04-01-2010, 02:26 PM   #29
mycologist
mycologist's Avatar
The other way around. The boost gauge is supposed to match the manifold pressure. I would trust what you are seeing from the ECU and not your gauge or your butt dyno.
I've been suspicious of the gauge all along especially when it showed no effect of changing the actuator tension. It also falsely indicated the previous spring being low.
Sounds like you boost is a bit high now. Does it really not feel like it is hitting? Can you log the IAM or whether any knock correction is occurring or total timing?
__________________
Old 04-01-2010, 02:31 PM   #30
Myzkoo
Hmm, well, i will have a look at my gauge, but something has to be wrong as the car feels alot slower. Will change back to the stock wastegate and log again and see what it reads.
There was some kind of option in the software that showed knocksensor (i guess correction?). but it only showed on/off. And it was reading "off" all the time.
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS:PA: 2004 Subaru WRX, Low Miles, Garage Kept, BIG POWER jpjester Vehicles for sale 12 10-15-2008 02:33 PM
Help!! Boost tap issues 96 wrx RECKLIZ STI Engine Modifications 3 02-06-2008 04:58 PM
CEL Codes for WRX and STi YBNormal07 Maintenance, service, and repair 2 06-12-2007 01:20 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
