Results 1 to 6 of 6
This is a discussion on oil pressure question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I realize that different oil weights and different filters will change the oil pressure. I have not changed my oil ...
    Registered User svynx's Avatar
    Aug 2008
    Hellam, pa
    I realize that different oil weights and different filters will change the oil pressure. I have not changed my oil weight, but I did change my filter. My question is this: what (on average) pressure should the oil be at when starting up/idling after warmed/running on the highway? With the new filter I have on, I'm running about 107psi on startup, and roughly 87 psi going down the highway at 65mph. My old filter (Fram) had me about 93 psi on startup and about 82 psi at 65mph.
    Just a little info: 02 wrx, stage 2, about 15psi at full
    I have the Q-horsepower full synthetic oil, 5w30
    Owner of the Budget Baller
    Bugeye Mafia #201
    Current mods: CAI, SPT exhaust, D-specs w/RCE Yellows, F/R Group N top hats, JDM lip kit, LWFW, F/R sways and endlinks, morettes, tuned at Agile Auto (10/9/10)
    Next project: EvoIII-16g, pnp, 850 injectors, fuel pump, and a little secret.
    Aug 2008
    Kennett Square, Pennsylvania
    Both of those numbers are more than sufficient...When I'm fully warm at idle I'm around 30 PSI and cruising at 65 I'm around 70 PSI...
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    what filter do you have now? Is it a factory filter?
    Lead Wrench @ WTF Tuning, LLC
    Jan 2008
    Nebraska
    I run Valvoline full synthetic 5w-40.
    ~95 psi cold start
    ~30-35 psi at hot idle
    ~75 psi cruising (RPM > 1800 or so)
    Aug 2008
    Hellam, pa
    It's a Purolator filter. Advance Auto Parts was running a deal on the oil that I use. Figured I'd at least give the filter a try. I'll see what it pulls out in 2000 miles when I do my next oil change.
    Ok, I won't worry that much anymore. Thanks everyone.
    Bugeye Mafia #201
    Aug 2008
    No prob. dude....Without oil psi. there would be no engine...
