Results 1 to 6 of 6
This is a discussion on Brake Lights but no Tail Lights... Help!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello, I recently discovered I had a brake light out so I bought the replacement bulb at Schucks. According to ...
    Nov 2004
    Unhappy Brake Lights but no Tail Lights... Help!!!
    Hello,
    According to my manual the correct bulb is the model number 7440 for brake lights.
    So I bought that and installed them. I did have one hang up when replacing them where the bulbs were REALLY difficult to install into the light sockets.
    I looked at the bulbs and they have a slightly bigger round notch at the bottom then the stock ones I had did. With a lot of time and strength I got them in. Tested them and found that the brake lights work.
    Now I was told by another dirver that I do have brake lights but no running lights. I thought to myself maybe another pair of bulbs went out. Looked up in my manual and it says they are my brake/tail lights are the same bulb.
    So am I missing something here?
    Are the bulbs really suppose to be that difficult to replace?
    I feel very stupid at the moment....
    Thanks!
    C/N: Changed brake lights, now don't have working tail lights.
    Car: 2005 Subaru Impreza WRX Wagon
    Aug 2008
    Kennett Square, Pennsylvania
    Are you 100% sure they are the proper bulbs? They should be dual filament bulbs I believe if you installed single filament bulbs something like this could happen....
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    Sounds like you bought the wrong bulbs. Time to go get the right ones and reinstall.
    Lead Wrench @ WTF Tuning, LLC
    Moderator Donkey's Avatar
    Da boonies
    Are you sure you used the appropriate bulb in the appropriate socket?
    2002 FORESTER S
    1998 FORESTER S
    Nov 2004
    Yeah I concluded that the user maual is a liar.
    It stated for the wagon the brake lights are 7440.
    When they clearly are suppose to be 7443 with the dual filament.
    Oh well.
    Lesson learned.
    I will be installing the correct ones tonight me thinks....
    Thanks for the help guys!
    Aug 2008
    Quote Originally Posted by Brisky View Post
    Oh well.
    Lesson learned.
    No problem bro.
