A lot will depend on what's available. Compression test, wet/dry leak down test, cooling system pressure test, or even just plain luck if something shows up externally and you can spot a leak after all.
This is a discussion on white smoke, losing oil, bubbling coolant within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My 2006 wrx seems to be burning oil. I'm loosing oil and I don't see a leak anywhere. My exhaust ...
My 2006 wrx seems to be burning oil. I'm loosing oil and I don't see a leak anywhere. My exhaust is blowing out white smoke when i give it some gas. Also, when i start my car when the engine is cold, the coolant in the reservoir tank bubbles. I've heard solutions ranging from a cracked piston ring, to a turbo issue, to a blown head gasket. The car has about 50k miles on it right now. Anyone know what the problem is or the best way to diagnose it?
Stage 2 2006 OBP WRX TR
HKS Carbon Ti cat-back, Invidia DP, Cobb AP
Debadged, Painted Headlight Housing, Nightshaded tail lights.
Subaru drivetrain warranty 5 year 60k. Take it to
the dealer.
Lead Wrench @ WTF Tuning, LLC
