Results 1 to 7 of 7
This is a discussion on plastic doesnt like the cold within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I was in the process of re-installing my intake manifold after doing the TGV deletes and turbo inlet, and I ...
    Jan 2008
    Nebraska
    I was in the process of re-installing my intake manifold after doing the TGV deletes and turbo inlet, and I discovered that EVERY SINGLE one of my coil pack connectors was busted.
    Apparently when I took the connectors off the coil packs to remove the manifold, the little clip that keeps them on broke on all four of them. I was able to get a decent strength zip tie in there in such a way that I think it will hold, but we'll see.
    Anyone else ever have this happen? Coil packs are ~80$ new, so I really can't shell out 320$ just for that. I'm thinking of taking them all off, and epoxying the connector to the coil pack if the zip tie thing failed. (think what you will, but I've been doing some research and some guys have been getting away with zipties for quite some time)
    Aug 2008
    Kennett Square, Pennsylvania
    So you broke the tab on the coil pack or the connector itself? I have broken both on the EZ30's before and on a Forester XT...I have used just that...zip ties...I have never had a comeback from one so I think that is your best bet... I find it amazing however that all 4 broke...I usually just accidentally snap one...
    Jan 2008
    Nebraska
    Ya I broke the retaining tab that keeps the clip on.
    It was pretty cold when I was doing it, and the car was bone cold too. I'd say it was around 15 degrees.
    I had an idea last night though. If the zip ties don't work, I'll just pull off the coil packs and one by one superglue a little piece of plastic onto the coil pack male connector. (thats approx same dimensions of the one i broke). Then the female clips should stay on.
    Registered User Poohbear's Avatar
    Mar 2009
    Ohio
    Quote Originally Posted by xsnapshot View Post
    Garage
    Your vehicle is an extension of your skill as a driver, not a substitute for it.
    Stink-Eye Mob Member #21
    08+ Gauge install DIY
    Turn off your seat belt chime
    Jan 2008
    Nebraska
    Quote Originally Posted by Poohbear View Post
    Garage
    Got one. Its not heated though
    Aug 2008
    Ah not a bad idea, Ive never had a problem with zip ties though..lol...
    Aug 2009
    Canada/Ethiopia/Madagascar
    Living in an area where it's cold 4 or 5 months of the year means I break lots of plastic junk. I've resorted to utilizing my wife's hair drier at times as a heat gun substitute. Luckily my new office has a heated bay, so there should be less breakage in the future.
    ...Rob.
    [my photos]
