Noise coming from wheels. - Page 2
Results 16 to 30 of 32
This is a discussion on Noise coming from wheels. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Thanks! I dont have any tools here where I love, so I just need to find a torue wrench, or ...
    Registered User 2005sti's Avatar
    Jan 2010
    Trinity, NC
    Thanks!
    I dont have any tools here where I love, so I just need to find a torue wrench, or buy one.
    Or maybe, buy myself some tools.
    2005 Subaru Impreza WRX - FP 68HTA'd
    2007 Honda Civic Si (Stock) - Traded it for ^^^
    Blobeye Syndicate #728
    Oct 2005
    Late Devonian
    I do think it is possible that it is the brakes and would look at them ASAP regardless of whether it still squeals when you aren't pressing the pedal.
    Sep 2008
    Yeah, it sure sounds like the little wear indicator tab on the brake pads is rubbing, telling you it's time for new pads. On my past automobiles, the indicator would squeal with no brake pressure, but was nearly silent when pressure was applied.
  6. #19
    Jan 2010
    Trinity, NC
    How common is it though for one brake to wear before others? Shouldnt they were evenly?
    And why would the brakes cause it to squeal when moving forward while turning left, but make a grinding/rubbing sound when moving in reverse and turning left?
  7. #20
    Sep 2008
    Even wear or not, statistically speaking one side will start hitting the indicator before the other. Just pull a wheel and have a look.
    How many miles do you have on that set of pads?
  8. #21
    Jan 2010
    Trinity, NC
    Not sure about the miles on the pads, they were on it when I got the car, but Ill probably be changing them here soon.
  9. #22
    Jan 2010
    Trinity, NC
    Pulled the brakes, took a lood, nothing out of the prdinary. Torqued the lugs properly. Still makes the sounds.
    Going forward its a squealing sound, in reverse its a grinding sound. Only makes the sounds when i turn.
  10. #23
    Administrator
    May 2003
    How did you support the car when you removed the wheels? It sounds like you bent a backing plate.
  11. #24
    Jan 2010
    Trinity, NC
    Jacked it up from the side. Arent the backing plates in the rear? I ask cause this sound is coming from the drive side front wheel area.
  12. #25
    Jan 2010
    Trinity, NC
    I turned right, out of a gas station today and I could hear what sounded like scraping. Could the rotors be bent or something. Im out of ideas on what this could be.
  13. #26
    Administrator
    May 2003
    Quote Originally Posted by 2005sti View Post
    Backing plates are the thin metal shields behind all 4 brake rotors. If they are bent or contacting the rotor they make a lot of noise. If there is a rock or stone caught in that little space it will make a lot of noise. I'f also seen people jack up the car and put jack stands under the rotors bending the shields.
  14. #27
    Jan 2010
    Trinity, NC
    Well I pushed back on the little shield behind the rotor and took a look at them and I cant see any bends or contact with the rotor. Is this a wheel bearing issue? I dont think it is, i moved the wheel, but there was no play.
  15. #28
    Registered User Sooby-Doo's Avatar
    Dec 2005
    Tampa
    Quote Originally Posted by Trainrex View Post
    Agreed, I believe the dust plate is the issue as well. Just experienced it not 5 days ago when I put on my new axles, springs & struts.
    Pushing them back with a screwdriver may not be sufficient. I recommend removing them (its only 3 bolts) and drive around to see if that takes care of sound. Then you can just put them back on if you want...or leaving them off isn't a huge issue either, but they were put there for a reason.
    If not, at least you've easily ruled out a free, quick fix without unnecesarily buying new parts.
    Good hunting!
    S&R Built 2.5/2.0 '03 Hybrid w/ PE1818
    Scott Siegel Tuned 308whp/320wtq
    Vogtland Club Spec Springs on KYB AGX's
    ******* I BOOST, therefore I AM! *******
  16. #29
    Jan 2010
    Trinity, NC
    Quote Originally Posted by Sooby-Doo View Post
    Good hunting!
    Okay, if i take them off and the sound is still there, what could it be?
  17. #30
    Jan 2010
    Trinity, NC
    Okay, so I still have these stupid sounds. A squeaking/squealing high pitched sound when i turn to the left, a grinding sound when I turn to the right. Sounds like it is coming from the driver side front wheel. Its a 2005 WRX Sedan. I have done:
    1. Torqued lugs correctly.
    2. Check Brakes Pad.
    3. Checked dust shields and backing plates.
    4. Checked for a wheel bearing issue, doesnt seem to be the problem.
    What else do i do!? This is killing me.
    Do you think my rotors have something to do with it? Any help is much appreciated, Im about to have to take it in and spend some money on it.
