CEL and engine problem NOOOOOO!!!!!
Results 1 to 8 of 8
This is a discussion on CEL and engine problem NOOOOOO!!!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 2003 WRX. Today I was driving home from campus and my CEL started blinking (its usually on because my up-pipe ...
    Registered User sin2win's Avatar
    Nov 2003
    TtowN, AL
    2003 WRX. Today I was driving home from campus and my CEL started blinking (its usually on because my up-pipe sensor isn't connected). But my car started bogging down when I accelerated. I can feel my car pretty well and I could feel through the pedals there was some friction of some kind. I checked all the fluid levels and they are fine. When the car is idle there is a lot of movement in the engine block itself. In neutral if I pull the accelerator cable it smooths out but there is definitly something wrong. Has anyone else had this problem or think they may know what it could be? I can't let my WRX die I love that car.
    Why do we drive on parkways and park on driveways?
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    What CEL did you get? You simply cannot drive a car with a CEL on. You need to do the resistor mod and get that CEL cleared up. Now what other codes are stuck on that ECU?
    Lead Wrench @ WTF Tuning, LLC
    Nov 2003
    TtowN, AL
    I had a friend take a look at it and mentioned that it could be ignition coil corrosion. Where is the ignition coil located in the engine bay?
    Registered User Liquidr1's Avatar
    Oct 2008
    Greensboro, NC
    The CEl is usesless until you get the ECU scanned to know what codes it is giving. Go to autozone and they will tell you the codes and what they mean so you can actually begin to troubleshoot the problem.
    Until you do that no one here can really help you other than give you a random guess.
    2009 Impreza WRX Hatch.
    Cobb AccessPort: Cobb Protune @ Draco Performance
    346 ft/lbs 289 awhp.
    Perrin CAI.
    Perrin Performance Catback.
    Perrin Performance 3" catted downpipe
    SPT boost guage.
    Nov 2003
    TtowN, AL
    just took it to my friends shop, should get the code in about an hour. I hope it's not something serious like the piston cracked or something.
    Dec 2003
    Dallas, TX / Sterling, VA
    Pray and hope it's not an ID 10-T error code! If so, you're screwed. GL!
    Registered User hatefun's Avatar
    Feb 2009
    Clovis, New Mexico, United States
    did you check you intercooler conection couse thats what coused my 02 to do that
    Jan 2010
    lee's summit mo
    fail
    Quote Originally Posted by sin2win View Post
    so you dont have one ignition coil, you have four coil on plugs, two located on each side of the engine.. and that is not licky your problem.. now have you replaced your spark plugs in the past 30k if not start there.. deff sounds like a miss thou
