Hesitation before boost
Results 1 to 4 of 4
This is a discussion on Hesitation before boost within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a hesitation problem in my '04 STI. It happens more when cold and at first did not matter ...
    Jun 2007
    AL
    I have a hesitation problem in my '04 STI. It happens more when cold and at first did not matter when the engine got warm. Now it is getting worse and still hesitates when engine is warm. since the problem started I have changed my plugs(because they needed it anyway). I took the car to subaru and they said it was the rear O2. well i tried to tell them that i dont have a cat conv so what should that matter. to make it worse they did not even check the O2. It was not even hooked up.
    I am thinking MAF has maybe gone bad. I cant really find any on the web that arent used and subaru quoted me $200+. I have a perrin C/A intake, and a 3" turboback exhaust. I cleaned O2 but i dont know if it made much of a difference. I did unplug the thing and drove around the block and the problem seemed to do the same thing only worse. I dont know if that was just adding to another problem i have. I have the new software update and do not have any other upgrades. NEBODY have any suggestions?
    Registered User Poohbear's Avatar
    Mar 2009
    Ohio
    your O2 can still cause issues with no cat... Do you have a check engine light?
    Your vehicle is an extension of your skill as a driver, not a substitute for it.
    Stink-Eye Mob Member #21
    08+ Gauge install DIY
    Turn off your seat belt chime
    Jun 2007
    AL
    nope
    no cel whatsoever and I have hooked the O2 back up but it didnt make a bit of difference either way
    Feb 2010
    brian is that you mF!? i was gonna look some **** up fo ur ass but nvm u got me beat to the forums
