my poor engine
Results 1 to 15 of 19
This is a discussion on my poor engine within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; my engine started smoking realy bad blue at start up then white when runing temp even with out turbo...
    Registered User eddywrx's Avatar
    Oct 2009
    stratford nz
    Angry my poor engine
    Registered User Stitches's Avatar
    Feb 2010
    The Woodlands, TX
    Sounds like coolant. Hows the level on your reservoir?
    Last edited by mycologist; 02-17-2010 at 06:17 AM. Reason: OOPS, SORRY - clicked the wrong button
    Oct 2005
    Late Devonian
    That would explain the white. The blue is probably oil.
    Sounds bad, sorry.
    Oct 2009
    stratford nz
    Quote Originally Posted by Stitches View Post
    the coolent is full so cant be that never has used any coolent sice i put engine in
    Registered User Focusguy87's Avatar
    Oct 2009
    STL & central IL
    Quote Originally Posted by eddywrx View Post
    If it just smokes at start up most likely valve stem seals. If it smokes at idle and while running I would say piston rings.
    Run a compression test and it will give you a good idea whats wrong.
    Oct 2009
    stratford nz
    its got cast pistons and i was runing 16psi so im finkin dats not good so i prob got a stuffed piston and wen all this happend i only had 4psi boost
    Oct 2005
    Late Devonian
    I understand you're frustrated but please don't dodge the swear filter
    How are you running it without the turbo?
    16 psi is no problem on an EJ205 with a decent tune.
    What are the specifics on the car (year, model, mods etc.)?
    Oct 2009
    stratford nz
    blocked of oil feed 2 turbo and oil return and water lines then took turb of 2 c if i had a f**kd turbo but no 1996 gf8 ej20g stock ecu no tune fmic ssqv manual conversion 4 $150 132,oookm prity low 4 1 of these
    Oct 2009
    stratford nz
    have got heads off have suffed piston 4 but will be lookn and useing a closed deck blok and putn forged inturnals in
    this is subaru country wher on a quiet day u can hear the mitsi's rusting
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Uh....WUT?
    Lead Wrench @ WTF Tuning, LLC
    Oct 2009
    STL & central IL
    Quote Originally Posted by LPPTundWRX View Post
    Uh....WUT?
    Yea not sure what he was trying to say. The only point I received was that the piston failed and he is building a new motor..lol
    Jan 2005
    Eh, whaaaaa?
    This thread has given me a headache of epic proportions. Grammar, people, grammar!
    Cody
    Oct 2009
    STL & central IL
    Really PSI has nothing to do with an engine failing.....up to a point. Its all in the tune and how accurate your timing and afr's are. If you were making modifications and not changing the tune that is most likely what caused the motor to fail.
    Snap a pic of the piston I would like to see the top. Any signs of deto or scoring from the heat?
    Oct 2009
    stratford nz
    couple of pics
    well guyz what du u think
    Oct 2009
    stratford nz
    piston
    piston stuffed lol
