my poor engine - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
This is a discussion on my poor engine within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; That is detonation. Broke the ringland and excavated out a hole probably. If you don't fix the setup for the ...
    Oct 2005
    Late Devonian
    That is detonation. Broke the ringland and excavated out a hole probably. If you don't fix the setup for the correct AFR & timing it will happen again. Look how clean the top of the piston is that didn't fail - totally lean. Look at the scuffing in the two corners on the bore. The bad one has oil burned onto it from the blowby.
    Engine Basics: Detonation and Pre-Ignition
    Registered User eddywrx's Avatar
    Oct 2009
    stratford nz
    hav put sti pistons in
    this is subaru country wher on a quiet day u can hear the mitsi's rusting
    Oct 2005
    Late Devonian
    Quote Originally Posted by eddywrx View Post
    NOT GONNA HELP - read the link.
  6. #19
    Oct 2009
    stratford nz
    also have replaced coil packs as were stuffed
