Pictures are worth a thousand words here...
Are you located in the U.S.? The only thing I can kind of think of up around there (to the right of the brake pedal) is the BIU..I have seen these cause some very very very odd problems before..So is this the closed deck EJ22 with EJ20 Heads? Also..there are two super multiple junction plugs right between the battery and the washer bottle on the drivers side that jump the gap over to the intake manifold (assuming this is a USDM car)...They make the pin outs so small in these..I have gotten WRX's and STI's with no start conditions and again some seriously odd problems because the pins back out of the terminals of these connectors...and its one of the last places "joe at the local garage" decides to look....![]()
LinkBack URL
About LinkBacks
