Get the code read. CEL = DTC = possible solution to your problem.
This is a discussion on my wrx dies :( plz help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; so i got my subie from the auction about 4 months ago.had to get all new valves. its an '03 ...
so i got my subie from the auction about 4 months ago.had to get all new valves. its an '03 wrx, and i put the motor back in, hooked everything up and started it. it was running fine, but a couple of days later i started it again and the check engine light turned on. Then, i revved it, and once the rpms start dropping, they fall almost to 0 and sounds like the car is about to die and then catches itself.so i took it for a test drive, and wen i start slowing down, it does the same thing but actually dies :s. i was told that it could be a sensor. any ideas? thnks
