Lock Cylinder pushed in, any thoughts on a better repair?
Results 1 to 2 of 2
This is a discussion on Lock Cylinder pushed in, any thoughts on a better repair? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; About 6 months ago I came out in the morning to find my lock cylinder pushed all the way in ...
    Aug 2008
    About 6 months ago I came out in the morning to find my lock cylinder pushed all the way in and door handle way loose. I thought it was an attempted breakin and took it to my local body shop who saw the bolt had come out and fixed it. Now just several weeks ago, it happened again just over lunch, this time not quite as pushed in. Both times, the door handle was loose. This seems to be a common problem, I'm guessing from checking the door is locked by pulling on the handle. Is there a better fix other than just replacing the bolt(s) in the lock?
    Registered User jwsmith0438's Avatar
    Apr 2009
    Texas
    It is a common problem but an easy fix. You have to put some blue loctite on the bolts or it will keep happening. while the door panel is off it would be a good time to check your door glass bolts they probably all need to be re-snugged a bit all of them
