Results 1 to 15 of 26
This is a discussion on Check Engine light comes on when accelarating hard. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ever since I went catless, my CEL will pop on when i accelerate hard, when it happens it feels like ...
    Registered User jmb8806's Avatar
    Apr 2007
    downingtown pa
    Ever since I went catless, my CEL will pop on when i accelerate hard, when it happens it feels like the fuel cuts out, it seems to happen between 80 and 85 mph. The light stays on, but after a few starts it clears itself. any suggestions???
    Post the code, post a list of mods done to the car, and see if someone can help.
    Apr 2007
    downingtown pa
    my mods are
    spt catback
    HKS catless DP
    spt intake
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Quote Originally Posted by jmb8806 View Post
    my mods are
    spt catback
    HKS catless DP
    spt intake
    I would guess you need a tune....when I put my turbo back exhaust on this same thing happened to me...then I got it tuned and it has never happened since...
    Wait...do you have an 06/07 with a catless downpipe...if so..get tune NOW!
    <-------- Taylor Swift.
    99.5 Jetta...I hear they make 90 to the wheels....
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
    ClubWRX.net Vendor PREracing's Avatar
    Nov 2006
    GRESHAM, OR
    overboosting most likley.....common thing when going catless on 06 and up wrx. I too recommend a tune
    bobby@preracing.com
    Performance Race Engineering
    503-619-0055
    preracing.com
    Follow us on Twitter
    Friend us on MySpace
    Oct 2005
    Late Devonian
    Get a stage II map or tune ASAP (as said above). You can't run the car hard safely as it is now.
    If that doesn't fix it get a DP with a cat and/or get an external wastegate.
    This thread assumes you have a stage II map:
    Boost creep / fuel cut
    Apr 2007
    downingtown pa
    ok so i got an AP and tuned to stage II and im still getting the same results the code is a P0244...im guess the next step is to get an external waistgate?
    Aug 2009
    Canada/Ethiopia/Madagascar
    CobbTuning.com - Service Bulletin: 07 WRX/STi Overboosting with Catless Exhaust
    Edit: my super sleuth skills indicate that you have an 06, but it's likely that the same applies to you going by a quote from their site:
    Please note: The catted version is recommended for the 2006-07 WRX, due to possible boost spiking while running catless
    ...Rob.
    Apr 2007
    downingtown pa
    i have an 06....
    Aug 2009
    Edited prior to your reply, they mention the 06 as well. Lots of threads here and elsewhere discuss the issue.
    ...Rob.
    Apr 2007
    downingtown pa
    where is the waist gate located
    Aug 2009
    There's a picture in the link...
    Here's some more reading: CobbTuning.com - How Subaru’s Factory Boost Control System Works
    ...Rob.
    Apr 2007
    downingtown pa
    so do u think that getting a catted DP is my most deffinate way of fixing my problem then
    Supporting Member mjboudreaux77's Avatar
    Sep 2007
    Northern Vermont
    I have read that leaving the stock catback can take care of the problem. Assuming you still have it around, this might be your cheapest and quickest solution. I believe all you need is a little bit of back pressure which the stock catback will provide.
    If I don't die by Thursday, I'll be roarin Friday night - Jimmy Buffett
    Apr 2007
    downingtown pa
    yeah but wont i loose some power then?
