Whirring / Whining noise related to turbo
Results 1 to 3 of 3
This is a discussion on Whirring / Whining noise related to turbo within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; This past weekend a buddy and I were working on my car trying to address what seems like the fairly ...
    Nov 2008
    Bellingham, WA
    Question Whirring / Whining noise related to turbo
    This past weekend a buddy and I were working on my car trying to address what seems like the fairly common problem of a gas smell. After sniffing around for a minute, we found a hose underneath the intercooler that was not properly connected to the engine. So, we removed the intercooler, re-connected the hose, and hooked the intercooler back up. Everything seemed fine until a few days later, I was driving up to the mountain when I noticed a whine coming from the engine. It definitely seemed related to the turbo -- the noise started as the turbo pressure gauge approached 0, and became higher volume and pitch the higher the pressure. While the noise seems to be related to the turbo, it sounds like it's coming from the other side of the engine compartment.
    Any ideas of what I should be looking for?
    -- '02 wrx wagon
    The leak you may have generated when r/r the IC.
    Apr 2010
    I'm having the exact same issue after changing my up pipe. I thought I just didn't tighten the bolts enough, so I retightened everything on the up pipe and am still having the whining noise. It sounds like someone is sitting in my engine bay blowing on a New Year's Eve noise-maker anytime my boost spools up over 5 psi. I was starting to suspect the IC, but would love to know what exactly to look for.
    Any help would be GREATLY appreciated!
    Thanks!
    Aaron
