Results 1 to 5 of 5
This is a discussion on Oil change turns to oil leak... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I bought my car about 2 months ago (2003 WRX Impreza) the first thing I did was changed the ...
    Registered User twells8553's Avatar
    Jan 2010
    Huntsville, AL
    So I bought my car about 2 months ago (2003 WRX Impreza) the first thing I did was changed the oil and filter. About 2 weeks ago I started see oil drops under my car. Someone told me that there was something special about WRX's when changing oil. Did I mess something up?
    Aug 2009
    Canada/Ethiopia/Madagascar
    Where's the oil dripping from?
    Did you forget the gasket for the drain plug? If you bought a Subaru filter it should have included a new gasket.
    ...Rob.
    [my photos]
    Jan 2010
    silly question but did you remember to oil up the filter gasket so it creates a seal?
    last time I was changing the oil in my car, it went from oil change to boiling hot oil shower... wasn't fun...
    Registered User Pactin's Avatar
    Nov 2007
    California
    Where are the oil drops located beneath the car?
    Did you use an OEM oil filter?
    Did you install a new crush washer on the drain plug?
    --Justin
    Hawk-Eye Alliance #128
    Registered User Aspen700's Avatar
    Mar 2006
    New Jersey
    like it has been said the first thing is to see where the leak is. a subaru oil change is just like most other car oil changes. oil out, change filter, oil in.
    '04 Aspen White WRX
