| Home | Forums | Gallery | Register | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
| General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here! |
| Advertise On ClubWRX | ||
LinkBack | Thread Tools | Rate Thread | Display Modes |
#1 (permalink) |
wont start
hey guys i got a 02 wrx and last night i was driving it when all of a sudden it starting losing power (seemed like running out of fuel) then the car just stalled out no check engine light came on. i pulled over and popped the hood and the turbo was glowing bright cherry red. i got it towed home and tried to start it this morning and it wont start it cranks but sounds like its not firing. i checked all my fuses and they are all good i am going to check the fuel filter when i get home and see if that is clogged. anyone got any advice? the car is basically bone stock only thing done is a cat back exhaust
#2 (permalink) |
How many miles are on the vehicle? Check the basics first...how is the battery? charging system? Make sure your getting fuel, spark, and air to the cylinders... Did the car overheat at all? Do you have a massive air leak somewhere? Usually when the exhaust glows red it means the vehicle is running way lean...I'm very surprised the CEL didn't illuminate...did you check the ECU for codes? Wait..your 100% sure there is fuel in the vehicle right?
#3 (permalink) | |||||||
Quote:
Quote:
Quote:
Quote:
Quote:
Quote:
Quote:
#4 (permalink) |
hmmm...well what you could do is pop the feed line off of the rail...the line which goes from the fuel filter to the rail....stick that line in a bucket and have someone crank the engine..if the fuel filter is clogged obviously a minimal amount of fuel will come out....Any maintenance history? I hope its not the timing belt...
#5 (permalink) |
i just bought the car a little over 2 months ago and the old owner replaced the timing belt so i don't think that is it i will try the fuel filter when i get off work today. just got an oil change done. the car has also been starting kinda hard lately when its high 20s to low 30s it starts like its subzero out so maybe ****ty gas and freezing lines? first time ever riding in a taxi and don't want to have to do it again tomorrow so all info is appreciated.
#7 (permalink) |
Yes the ej20 is an interference motor...if the belt actually broke you would most likely have a fast crank also...perhaps it just skipped...I have seen the dohc subaru timing belts jump before and not bend valves however that is somewhat rare...
#9 (permalink) | |
Quote:
The 04 has all the details around what to do to inspect it so I'm assuming the 02 would as well. If the old owner replaced it I doubt it is the issue. But still... Is your fuel pump working? Have you checked your compression? or air leaks? Spark plugs? |
#11 (permalink) |
well i broke down and took it into a shop thats down the street from my house they had it all day yesterday and couldn't figure a single thing out they just said it could be a blown turbo or burnt valve or blown motor they weren't sure they said it had plenty of fuel pressure and that all the coils were good and there was spark. so now i brought it to a shop in town the specializes in Subaru's so i will let you all know what i find out. i am starting to lean more towards bad ecu or blown motor hopefully some stupid little sensor or wire is bad though.
#12 (permalink) |
hmmm perhaps the crank sensor developed a dead spot...though you would usually get an intermittent hard start if that was the case...I'm still leaning towards a timing issue at the moment...but yea keep us informed...
#13 (permalink) | |
Quote:
Good luck, I hope they figure it out. |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Car won't start | hakira | General Maintenance, Troubleshooting & Accidents. | 12 | 10-16-2007 08:51 AM |
| No Fuel Pump Noise.??? Wont Start :( | Solveit-UK | General Maintenance, Troubleshooting & Accidents. | 11 | 08-27-2007 03:26 AM |
| HELP!!! Turbo Timer Install... Car wont start | STL WRX | Everyday Impreza Talk | 13 | 02-21-2005 08:21 PM |
| built motor wont start calling all subaru gurus to arms | jdizzle | Engine Modifications | 17 | 12-15-2004 02:01 AM |
| please explain - roll start | veteq | Comparison: WRX vs World | 20 | 09-04-2003 09:17 AM |
