Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
This is a discussion on 2002 Subaru WRX rough idle/stalling? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by DorBink Right and the scanner comes with instructions, but it's pretty simple. Plug it in turn your ...
    Jul 2006
    Upstate NY
    Quote Originally Posted by DorBink View Post
    Right and the scanner comes with instructions, but it's pretty simple. Plug it in turn your key to power, but don't start and then push Scan on the scanner and then scroll through the codes.
    Thanks for your reply.
    I am reading through different scanner reviews and some aren't compatable with certain Japanese makes. Do you guys have one that you like and has been good to you. I also have
    CRX but pretty sure if that is OBD2...
    It would be nice to find one that covers both...just tihnking outloud.
  2. #17
    Registered User DorBink's Avatar
    Sep 2009
    Houston, Katy
    Actron®
    Actron Pocketscan. That's what I have. I never checked for compatibility. My buddy had one I tried it and it worked. The codes in the back of the book help. There are also Subaru specific ones: Subaru Trouble Codes - 1996 & newer Subaru-specific OBD-II Trouble Codes
    The Pocketscan is the cheapest and will do the trick, the more expensive ones just have more buttons and will actually display words on what the code is vs just the code.
    This little guy is worth it too for when you go to get your yearly emmisions tests. It will tell you if you have any problems so you don't waste your time at the inspection place being told you have failed!
  3. #18
    Jul 2008
    San Antonio
    Quote Originally Posted by 2002BlueWRX4eat View Post
    Do you have engine management yet?
    Paul
    2007 MS3
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
  4. #19
    Jul 2006
    Upstate NY
    Actron®
    I will pick up one of these today...can't believe they are so checp now. They used to be expensive!
    Quote Originally Posted by pzr2874 View Post
    No, car is stock except BOV.
    I just got a cat back from a buddy of his 02 wrx.
    Why do you ask?
    Thanks for the replies
  5. #20
    Jul 2006
    Upstate NY
    I bought the PocketScan today...hooked it up...No codes...hmmm
    The light is off, but I though it may still be stored.
    I will hook it up if it comes on again
  6. #21
    Jul 2006
    Upstate NY
    So I changed out the fuel filter and cleaned my MAF sensor (was filthy btw) and the idle is much better. Did both at once, so not sure what fixed it.
    But today the check engine light came on..I scanned it and got the code:
    P0301
    Car feels fine, but the light came on again...2nd time this week.
    I drove 30 minutes, parked, let car sit for 20 minutes, went to start it and it was turning over but not starting. Took 3 tries before it started. The light came on about a mile later.
    Any suggestions?
  7. #22
    Oct 2005
    Late Devonian
    P0301
    Any suggestions?
    That code can be a PITA.
    Have a look through this - see Donkey's first post etc.
    Stumped with a misfire problem
  8. #23
    Jul 2006
    Upstate NY
    Thank you very much. Excellent reference post.
    Does anyone know how common it is that coil pack go. I did the plugs last year in hope of fixing the problem with no luck.
    I will start going through the list in the meantime.
    BTW, rough idle is back today. It was nice the 1 day it was gone!
  9. #24
    Oct 2005
    Late Devonian
    I'm not sure what all problems the IAC valve may cause, you might want to read up on that.
    Seafoam next probably. You can find threads about how to suck it into the motor correctly through the BPV line. Never done it personally so form your own opinion (I wouldn't personally put it in my oil ever). Definitely don't hydro-lock your motor and change the oil when you are done.
