Results 1 to 2 of 2
This is a discussion on Tps help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; When testing the TPS with a volt/OHM meter on the 20K scale, I know U put one lead on the ...
    Registered User Jerembo47's Avatar
    Nov 2009
    San Diego, CA
    Question Tps help!
    When testing the TPS with a volt/OHM meter on the 20K scale, I know U put one lead on the middle prong and then the other lead on either side. I was wondering when testing should both sides do the same thing? The right side transitions pretty smooth, but the other side stays at 3.14
    Moderator Donkey's Avatar
    Da boonies
    One is voltage in the other is voltage (signal) out. All that matters is voltage signal out.
    2002 FORESTER S
    1998 FORESTER S
