Possibly something to do with your drivetrain. When you step on the gas your taking slack out of the drivetrain... When there is slack from the sound of it is when your hearing the noise. Because its happening in all gears im going to say maybe the diffs?
Its hard to diagnose something like this with out more information or being able to hear the noise... Do you at least have a general idea where its coming from? Front rear? Center? Do you feel it in your shifter? Or steering wheel? Any problems shifting going into gear? check your fluid levels lately? We have to start somewhere other then i have a noise its odd I cant describe it what could it be?
LinkBack URL
About LinkBacks
I own a 03 wrx. It drives nice and everything but every now and then there is an odd noise that is hard to describe but it is like a metallic rumble.It makes this noise mostly when i am in third and fourth gear, and it only does it when i am in gear and am coasting fast(using my gears to help slow me down)...when i give it any gas the noise goes away. I first thought that it might be a wheel bearing but I really have no idea at what is causing it
, any help or ideas would be greatly appreciated. Thanks!
Stink-Eye Mob Member #21
