??What oil should I use?? - Page 16
Page 16 of 29 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 226 to 240 of 429
This is a discussion on ??What oil should I use?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by dead_ringer Walmart has 1 quart bottles That's good to know! I know buying 2 gallon jugs of ...
  1. #226
    Palmyra, NJ
    Quote Originally Posted by dead_ringer View Post
    That's good to know! I know buying 2 gallon jugs of it would be cheaper...I just didn't feel like spending that extra $28 at that time cause I already bought a ton of **** to do 2 other oil changes besides mine.
  3. #227
    Feb 2014
    I have to buy four gallons of T6 to do both of my cars at once and only have 3 quarts left over lol the M3 holds 8 quarts slightly overfilled by itself.
    Sent from my SM-N900V using Tapatalk
  4. #228
    Registered User jsantos1082's Avatar
    Aug 2012
    River Edge, NJ
    I bought 6 bottles of the quarts at walmart. I basically cleaned out their shelf haha. Those quarts are hard to find.
    JOE
    2013 WRX DGM
    Stink Eye Mob #82
  6. #229
    Palmyra, NJ
    Quote Originally Posted by hybridEJ View Post
    BMWs take a metric **** ton of oil. My old 318i would take almost 6qts! 1.8L engine!
  7. #230
    Palmyra, NJ
  8. #231
    Feb 2014
    7.2 filled and I run 8 because M racecar and I go hard
  9. #232
    Palmyra, NJ
    What does the manual say to put in your M? Usually adding more oil doesn't mean that it's going to work better...in fact there have been many cases out there in many different cars where more oil causes more problems.
  10. #233
    Feb 2014
    7.2 filled as mentioned above. It's only 8/10ths over and it's a very common practice for those who have owned them for years and drive them hard. It's not enough to cause whipping from the crank. The M S52 engine also goes through a quart every 1500-2000 miles so it's not a big deal.
  11. #234
    Feb 2014
    Alaska
    I haven't gone through this whole thread yet but I was actually wondering the same thing. I own a 2003 WRX with 61,700 miles on it. When I talked to a tech at the Subaru dealer, he said that I should NOT use Mobil 1 synthetic, but he recommended Shell's Rotella synthetic oil. He also said that I should switch to 5W40, but when I looked for 5W40 Rotella, the container said "Diesel Turbo Charged Engines". I'm a little hesitant on their recommendation since my car is not a diesel; should I just stay with 5W30?
  12. #235
    Feb 2014
    Tons of people with non diesel engines are running it.
  13. #236
    Feb 2014
    Alaska
    nvm I just read a couple posts back, looks like someone else was told the same thing! Looks like I'll be trying the Rotella oil for my next oil change!
  14. #237
    Feb 2011
    Austin, TX
    http://s02.static-shell.com/content/...6-brochure.pdf
    It carries an SM approval, thus it is safe for use in our vehicles. In fact, UOAs have come back with fantastic results. Also, if you're looking for single quarts I've had luck at Walmart.
    The 3 that are recommended often are Castrol Edge (with syntec) 0w-30 (german formula, at autozone), Mobil 1 0w-40, and Rotella T6 5w-40. Rotella is the most affordable and probably the most durable.
  15. #238
    Feb 2014
    Alaska
    Yeah that what I figured after reading a few of the posts. I looked everywhere for 5W40 and couldn't find it until I saw the Rotella, but they didn't tell me it was diesel oil though. So how about a Wix oil filter?
  16. #239
    Feb 2011
    Austin, TX
    Quote Originally Posted by dljackson907 View Post
    WIX 57712 - Oil Filter | O'Reilly Auto Parts
    Either use the genuine subaru filters or the one up there. There's Purolator that has the proper relief valve pressure (23psi), but I've heard it touches the header. The big thing here is the relief valve pressure. Our cars require it to be much higher than most other cars. You definitely don't want to be bypassing your filter more often than not.
  17. #240
    Feb 2014
    Alaska
    Definitely going to try the T6, I already can't wait to do my first oil change on this car!
