??What oil should I use?? - Page 13
Page 13 of 29 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 181 to 195 of 429
This is a discussion on ??What oil should I use?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Find the mechanical fault....
  1. #181
  3. #182
    Jul 2013
    Tampa, FL
    My results with Chevron Delo 5w-40 and Purolator oil filters:
    Chevron Delo 5w-40 - 2010 WRX Results
    -2010 WRX
    |AEM Intake|Cobb Stage 1|
  4. #183
    Jan 2013
    Oregon Coast
    I am using mobile 1 5w-30 since my oil change 4 months ago and aprox 4,000 miles i have added nearly 2 qts of oil. Any Idea whats up
  6. #184
    Mobile is in Alabama.
    Your consumption is 1 qt every 2,000 miles. What is the permissible normal consumption stated in your owner's manual? For my car the manual states twice that. Yours may vary.
    You can experiment with other viscosities and brands provided the oils you try meet the viscosity and spec ranges listed in the manual. Be aware though that consumption can be erratic with a new oil so if you change, check more frequently. Eventually you'll see how the next oil behaves and won't have to check as much.
  7. #185
    What year is your car? The post above yours shows good data for Delo, and it is less expensive than Mobil 1. However I don't think it meets the warranty spec so for a newer car I'd find something that does, to the letter, and keep dated receipts.
  8. #186
    Palmyra, NJ
    Mobile 1 has never really been well-received as a quality oil to be used in Subarus. I've seen a lot of stories where it likes to burn off much quicker than other oils.
  9. #187
    I've used the 10W-30, 10W-40, 0W-40, and 5W-40 Mobil1 in my Subaru. I liked the 5W-40 best, this is their diesel truck oil. The motor used oil with all if them but nothing terrible. Now I just shop by price. Currently has Mobil1 10W-40, for example. Just top it up.
  10. #188
    Apr 2013
    I've got 6,xxxx miles on my '13 WRX. I changed the FF @ 1,000 miles and changed the oil again @ 5,000 miles, both times I used SN M1 0W-40. The first filter replacement was a Subaru blue and the second was the black filter from fredbeansparts.
    I've had zero noticeable consumption and I had my intercooler off about a month ago and didn't see any oil present in the tubbing.
    I have no interest in trying any other oil at this point in time.
  11. #189
    Jan 2009
    Md
    I've been using rotella I guess the T6 or t5... whatever most people use, but I've read some things about it that make me wonder how good it is. I've used German Castrol 0w-30... after 3500 miles I didn't like how black it was and how burnt it smelled vs. the Rotella though. I've heard the Valvoline (which one I don't recall) synthetic whatever now meets euro spec, mobil one supposedly causes spun bearings, so stay away from that royal purple had an issue a while back where it got in trouble for making claims that were untrue, so for me, they are not a trustworthy company.
    The real answer is... no one knows with these motors what is best. Blackstone labs tests oil, but there are certain things it misses and there are companies who can get MUCH more in depth of your oil to give you a much better picture of what is going on with it.
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
  12. #190
    Jan 2009
    Md
  13. #191
    iH4
    iH4 is offline
    Registered User iH4's Avatar
    Apr 2013
    the OC
    I've got a nice insight through Bisi @Bisimoto Engineering and going to be running 10w40 from PurOl:
    | PurOl USA
    Time for AWD fun! CBS 2013 WRX Sedan - SoCal - OC
  14. #192
    Do those actually meet the specifications? I don't see an API donut on any of the containers and the marketing speak states the oil "... exceeds API, ACEA and JASO performance requirements..." without specifying which requirements, anywhere that I can see.
    To me this implies these are not API oils. Am I mistaken? If they are not API oils they do not meet warranty spec.
    A picture of the back of any of the containers would be very telling.
  15. #193
    iH4
    iH4 is offline
    Apr 2013
    the OC
    That is for non performance oils. They only meet API, and do not contain zddp. This is high end stuff, tested and engineered to be used under high demand engines, race or street.
    Sent from my SPH-L710 using Tapatalk 2
  16. #194
    Quote Originally Posted by iH4 View Post
    OK however this means the oils are not suitable for use in Subarus under warranty. If you're out of warranty it's not an issue.
    EDIT: So they are API oils with donuts on the bottle?
  17. #195
    iH4
    iH4 is offline
    Apr 2013
    the OC
    Liked this Castrol bottle?
