MAF help - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
This is a discussion on MAF help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; If it is on the bottom line it is 750 rpm,which is normal when up to operating temps....
    Moderator Donkey's Avatar
    Da boonies,Va
    2002 FORESTER S
    1998 FORESTER S
    Registered User BrandonPaquette's Avatar
    Dec 2009
    Sudbury, Canada
    i know how to read an rpm gauge and the needle is sitting at 500 rpm
    Da boonies,Va
    Quote Originally Posted by BrandonPaquette View Post
    Good luck.................
    2002 FORESTER S
    1998 FORESTER S
  6. #19
    Dec 2009
    Sudbury, Canada
    could i get p0171 bank one to lean if i had dirty fuel injector???
  7. #20
    Jan 2010
    same problem
    I also got the CEL and checked it and turned out to be the system too lean bank 1
    I have a turbo back and bov no intake I don't know what to do.. I'm gonna try and clean the maf
    And maybe check the o2 sensor, it drives like crap stumples at low rpms until I hit boost
    And back fires quiet a lot, also ruff idel any ideas?
  8. #21
    Dec 2009
    Sudbury, Canada
    was the car sitting for anytime. my rad when at xmas and i waited 2 week to get a new one so the car sat there. after getting the rad in the car was idling rough and i get the cel
    p0171 but i put some injector clean and i have drove the car about 100 km with out the cel coming back on you should try. what year is the car
  9. #22
    Jan 2010
    Ya it was sittin over winter for about a month and then when I started it bamm I got this problem
    I have a 04 sti, what should I do? I'm thinking maybe get tuned and get the tank cleaned
  10. #23
    Dec 2009
    Sudbury, Canada
    i would remove the gas you can drian it there are to bolts by the rear dif. then put new gas 91 octane with some gas line antifreeze that has water remover (you can get at any part store) at the same time you should but some fuel injector clean to clean the injectors. when a car sits with gas in it the gas crystalizes and cloggs the injector. with clogged injector it limits the gas flow so there not enough gas compared to air so the o2 senor get a high o2 reading
  11. #24
    Jan 2010
    Thanks man gonna do that tomor let's hope for the best!!!
    Wish me luck boys
  12. #25
    Dec 2009
    Sudbury, Canada
    get back to use when you done
    Brandon Paquette
  13. #26
    Dec 2009
    Sudbury, Canada
    ok so i thought that i fix everything but i got the code taday after putting 60 km and and start the car 10 -15 time the p0171 system too lean (bank 1) but i did fix the low rmp at idle with injetor cleaner i donot know to fix this
    Brandon Paquette
  14. #27
    Jan 2010
    i drained the gass, put in new gass and used injector cleaner and fuel cleaner and nothing, it seems to help a little bit but not enuff
  15. #28
    Dec 2009
    Sudbury, Canada
    ok did you drive it with the clean in or just let it sit and run. have you cleaned the MAf and checked th o2 and have you over look all hoses
    Brandon Paquette
  16. #29
    Dec 2009
    Sudbury, Canada
    when you unplug the MAF and the car runs the map system dose the cyctem take information for the front anf rear o2 sensor to help decside how much gas to add?
    Brandon Paquette
  17. #30
    Da boonies,Va
    Stick to one thread. Bumping up differnt posts just to ask the same question gets very annoying and is called "multi posting".
    2002 FORESTER S
    1998 FORESTER S
