Results 1 to 5 of 5
This is a discussion on changing clutch fluid within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I've got an 03 wagon with 95,000 on it, and have had it for two months now. I figure the ...
    Nov 2009
    I've got an 03 wagon with 95,000 on it, and have had it for two months now. I figure the clutch fluid has never been changed out. I searched the forums but didn't really find the info I need. Could someone explain the proper way of installing new fluid? Do I need a hand cyphon? Do I need to bleed it? Is it a two person job? All these questions and more!!! Anyway, thanks for helping my wagon.
    You have at least three options. I'll list them in order of complexity:
    1. Forget it.
    2. Use a syringe or turkey baster to remove some fluid from the reservoir, being careful not to remove too much so as not to introduce air into the system. Repeat once a week for a month. Then forget it.
    3. If you can access the bleed screw on the master cyl without removing the IC, great. Otherwise remove the IC, attach a drain tube to the bleeder, dress the entire area with rags, and have a second person work the pedal from inside the car for you. Depress the pedal, open the air bleeded for 1 or 2 seconds, close the air bleeder, release the pedal slowly, and repeat.
    Options 1 and 2 are IMO probably most popular.
    Registered User Poohbear's Avatar
    Mar 2009
    Ohio
    option 1 is my favorite...
    I would be more concerned with break fluid first...
    Your vehicle is an extension of your skill as a driver, not a substitute for it.
    Stink-Eye Mob Member #21
    08+ Gauge install DIY
    Turn off your seat belt chime
    Registered User LRPct's Avatar
    Jan 2006
    Lime Rock Park Ct...
    I found out the hard way that our clutch slaves are a total pain to bleed. Probally because it's lower than the resivoir. Working at a race school I've probally bleed 40 clutch and brake resivoirs in a day and I NEVER had the problems I had with the WRX. I finally had to pull the IC and unbolt the slave from the tranny and raise it above the resivoir to get a good bleed out of it. Wish I would have just left.. So I'd either go with the leave it option or the turkey baster...
    Moderator Donkey's Avatar
    Da boonies
    I just use a mighty vac.
    2002 FORESTER S
    1998 FORESTER S
