Is there proper grounding?
This is a discussion on HIDS flicker within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just installed h11 6000ks in my 2010 wrx and at first my right light flickered then stopped then the ...
I just installed h11 6000ks in my 2010 wrx and at first my right light flickered then stopped then the left. Then i got everything snugged up and tight and it was gone. But after driving around for a while i noticed on the back of the cars in front of me there was a slight flicker here and there, but it doesnt effect the actual beam at a distance. Would a resister fix this problem or what, any advice?
Its a plug and play,bulb to ballasts, ballast to stock relay, im sure its a power issue with them only being 35w, not 55w maybe the computer is confused? i dont know!
what kit did you get? is the flicker happening with bumps in the road? loose solder in the ballasts or just cheap bulbs? just a thought....
Your vehicle is an extension of your skill as a driver, not a substitute for it.
Stink-Eye Mob Member #21
08+ Gauge install DIY
Turn off your seat belt chime
Same thing happened to my o2 wrx my left headlight would flicker, then once i start driving it would stay on but once i stopED an a redlight they would both start to flicker again. i went to a shop an the said it might be the relay or the ballast. i replaced the relays an still flickered so i just went an bought a digital hid kit which does not require any relays. I pluged them in an nomore flickering![]()
