Results 1 to 10 of 10
This is a discussion on need help with lights within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; first off im not too good with electric stuff, my driver side head light went out, i tried replacing the ...
    Registered User diego04's Avatar
    Dec 2008
    first off im not too good with electric stuff, my driver side head light went out, i tried replacing the bulb and no go, could there be a short somewhere if so i have no idea whAT to do, all my other lights working fine,
    thanks
    Aug 2008
    Kennett Square, Pennsylvania
    There could be....So you replaced the bulb with a known good one? What happens if your outside the car with the headlights on and the new bulb in and wiggle the wires going to the bulb? anything? If that fails check for power and ground at the socket...
    Moderator Donkey's Avatar
    Da boonies
    Unless you have a multimeter you not going to get very far. Also its very important never to touch the glass part of a halogen bulb. The natural oils from you fingers will create a hot spot on the glass when they burn and cause the bulb to fail pretty quick (sometimes in a couple of minutes/seconds)
    2002 FORESTER S
    1998 FORESTER S
    Dec 2008
    multimeter huh.? can i buy that at wal-mart.? havent tried wiggling the wires, only bulb not working is the H1
    Aug 2008
    Quote Originally Posted by diego04 View Post
    Yes you should be able to buy one at walmart... they should be back in the automotive electrical section...pretty inexpensive there...
    Dec 2008
    sweet ill check them out,say i buy one.what should i look for/do
    Aug 2008
    Well If your 100% sure the bulb is good...check for B+ and Ground at the socket...
    Sep 2009
    hudson valley, NY
    while we are on the subject of headlights...my driver's side low beam light went out yesterday...i gave the housing a knock from the outside and it came back on and has remained on for the last 24 hours. I haven't had much time to investigate....anything other than what has been mentioned above that I should look for? I assumed it was the bulb on it's way out but after reading above maybe I'll check the wiring. Is the bulb easy to replace?
    -Dan
    2007 WRX TR
    Jul 2008
    San Antonio
    Take the battery out ( if I remember correctly)and unscrew the housing.... 15 minutes.
    Paul
    2007 MS3
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
    Sep 2009
    hudson valley, NY
    thanks!
    -Dan
    2007 WRX TR
