How many miles are on the vehicle? When exactly do the lights dim? Would this happen to be a 5spd manual? Do the lights dim when you throw it in neutral coming to a stop? How Is your idle? I would do a thorough visual inspection of everything make absolutely sure you don't have any loose connections or wires/excessive corrosion anywhere...How is the battery? I would def. load test it...
LinkBack URL
About LinkBacks
