| General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here! |
| Advertise On ClubWRX | ||
LinkBack | Thread Tools | Rate Thread | Display Modes |
#1 (permalink) |
power steering is stiff upon start
Hi all,
My power steering is stiff for the first minute or so after I start up my 02 WRX. It's so stiff I can barely pull out of a parking space. Then after driving for a short bit everything seems fine. Any thoughts on what might be causing this? |
#2 (permalink) |
Have you had a recent cold spell when you just noticed this happening? How is the P/S fluid level/condition? How is the P/S/ALT drive belt tension/condition? How many miles are on the vehicle? Have you had any recent maintenance done to the vehicle? How does the rag-joint look on the steering shaft coming out of the fire wall /..rusty/seized?? You could try lubricating that a tad and see if it helps...Ive seen these get all "aged with rust/road grimed up"...
#4 (permalink) | |
Quote:
#6 (permalink) |
The Mushroom Moderator
This guy is directionally challenged so if you watch it reverse everything he says about clockwise or counterclockwise.
YouTube - WRX Belt install
__________________
"From a little spark may burst a mighty flame." - Dante "The stitch is lost unless the thread is knotted." - Italian proverb |
#7 (permalink) | |
Quote:
#8 (permalink) | |
Quote:
#9 (permalink) | |
Quote:
#10 (permalink) |
Mine has done this for the last two winters, but it never lasts longer than the first time I turn the wheel. If I let the car warm up or give the throttle a little nudge while turning the wheel it seems to go away. There is no squeal noise when this happens for me so I do not believe it is an issue with a lose belt. I have not checked the Fluid, but haven't seen any leaks. I figured it is probably the power steering pump getting older and not having the fluid moving around as quickly as it used to on a cold start.
__________________
Torch Red 2002 Chevrolet Corvette Z06 46k mi. Black 2002 Subaru Impreza WRX 6-speed 94k mi. my mod list 10/08/2006 - 14.089@103.01 (5-speed with well worn clutch, no launch) "Six stars gleaming, five speeds breaking, four tires chirping, three differentials working, two liters screaming, one turbo boosting... it's what makes a Subaru all-wheel-drive, all we'll drive." for Bugeye owners my BOV thread Service Manuals |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| PLEASE Help steering stiff | Arson29 | Suspension & Wheels | 5 | 05-21-2008 10:58 AM |
| Power Steering Pump, Pulley, or Belt? | mterry | General Maintenance, Troubleshooting & Accidents. | 3 | 01-22-2008 02:19 PM |
| Power Steering Question | boosted scoob | Suspension & Wheels | 0 | 12-17-2005 07:39 PM |
| Power Steering Problem! Help!! | MidKnight | General Maintenance, Troubleshooting & Accidents. | 4 | 04-14-2004 06:25 PM |
