Turbo... Kicks in and out?
Results 1 to 3 of 3
This is a discussion on Turbo... Kicks in and out? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; If I had a turbo gauge I'd imagine the turbo would be reading max and bouncing back to 0 throughout ...
    Nov 2009
    If I had a turbo gauge I'd imagine the turbo would be reading max and bouncing back to 0 throughout 4k rpms to redline. I don't get it. I just don't have full power throughout the gear. I can feel it kick in and out throughout the whole gear.
    Any ideas? Do I need a tune?
    The car is stock aside from S2000 spark plugs and an AEM intake. No check engine light.
    I just moved from Florida to Oklahoma. Could the temperature be a factor? The spark plugs are a stage colder than stock, but I don't see that being a problem either.
    Oct 2005
    Late Devonian
    The cold very well might be making you overboost, then your ECU cuts it back. But that is one of many possible issues.
    There are a bunch of people having this problem right now - have a look at this thread and also look at the threads on the first page of the general maintenance forum there are several more.
    Spool Surges.... what does it mean?
    Registered User Blue Devil's Avatar
    Nov 2009
    Pocatello Idaho
    Check for vacuum leaks. My 04 wrx was doing the same thing and I ended up having a bypass valve gasket that was shredded causing my turbo to bounce around.
