Results 1 to 4 of 4
This is a discussion on tranny and differential oil?????? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hey guys I have 02 wrx stock with 78k automatic... what kind of oil should I use for the differential ...
    Registered User sudaka's Avatar
    Oct 2008
    NJ
    hey guys I have 02 wrx stock with 78k automatic... what kind of oil should I use for the differential and transmition and how much?
    Is it ok to replace the automatic tranny fluid, I was told cars (automatics) are never the same after.
    thanks
    "Take time to ponder which things you are most grateful for and which things are of greatest need in your life"
    Aug 2008
    Kennett Square, Pennsylvania
    If I could I would find out the history of the car and if the trans fluid has ever been changed...If you can find a shop that has an actual transmission flush machine such as BG which cycles all the old fluid out rather than just a drain a fill which basically does nothing, fore your only really replacing about 4 quarts which is in the pan itself...I would recommend reg. Subaru ATF for the trans and personally I use Valvoline 75w90 in the front and rear diff....
    Oct 2008
    NJ
    I don't have the cars history that's why I'm doing this... so thanks man!
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by sudaka View Post
    use Subaru's Synthetic "Extra S" for the differentials in my opinion.
