Results 1 to 3 of 3
This is a discussion on need some help please guys urgently within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My friend has this prob on classic wrx 97 import.... it has been all put back to origional so took ...
    Registered User donnas roo's Avatar
    Jan 2007
    Greater Manchester England
    My friend has this prob on classic wrx 97 import.... it has been all put back to origional so took dump valve off changed back air filter(panel) new plugs changed MAF (orange one) but still cuts out about 4000rpm... Has been on diagnostics machine and machine has said was MAF any ideas please
    Thank u ....
    Registered User Poohbear's Avatar
    Mar 2009
    Ohio
    If you changed the MAF maybe its the wiring from the MAF to the ecu? Perhaps a short somewhere?
    Your vehicle is an extension of your skill as a driver, not a substitute for it.
    Stink-Eye Mob Member #21
    08+ Gauge install DIY
    Turn off your seat belt chime
    Is the MAF on the right way? If it's reversed you will have problems. Does anything happen when you gently wiggle the wiring to the MAF?
