This is a discussion on Help!! 02 rex overheating.... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey fellas, need sum help! recently changed my radiator and thermostat and added new coolant. Drove it 10 miles, its ...
Hey fellas, need sum help! recently changed my radiator and thermostat and added new coolant. Drove it 10 miles, its was fine then started overheating slowly. Pulled into a gas station and coolant was leaking. Drove for one day then check engine lihht came on. Once i turn the car off, it would not start over. I had to reset the ecu and erase CEL. Car then started fine. Has anyone heard anything similar to this??
for EvoEatr! having overheating issues as well. my gauge did hit red! did i **** something up? what should I look for?
i have had the same problem lately, so i replaced the hose that was leaking coolant but my car is still running extremely hot and the turbo feels like it isn't boosting like it should. any suggestions?
