Results 1 to 4 of 4
This is a discussion on EJ20 leaking coolant from valve cover within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an 02 WRX wagon as a DD with 170K on it. This was very well maintained and runs ...
    Registered User BlueHeavenWRX's Avatar
    Oct 2005
    Philly, Schwenksville
    This was very well maintained and runs GREAT.
    Current mods are full catless wrapped TBE.
    SPT intake with K&N short ram
    Reflashed to Cobb Stg. 2
    Today I discovered a small coolant leak from the passenger side valve cover, at the lower rear part of the valve cover, then the coolant leaves a small trail going down the stock UP to the stock header.
    My questions are...
    1. Can I still drive it, if I monitor the leak, add coolant as needed, and don't drive hard. The leak is very small.
    2. Is there an easy way to replace the valve cover gasket, without pulling the engine, or would it be counterproductive.
    I told myself, if I ever had to pull the engine for any reason, I would just stick a new built EJ25 in there with P&P EJ20 heads. But I have too many projects going on to do this right now.
    Let me know what you think.
    Thanks!
    Oct 2005
    any advice on this???
    Registered User JRB1987's Avatar
    Aug 2008
    I would pressure test the cooling system to find the real leak.
    Replacing your valve cover gasket would not correct any coolant leak issue as there is only engine oil inside your valve covers
    Jul 2004
    Seattle, WA
    JRB1987's right, the valve covers should only contain oil.
    Have you checked to see if antifreeze has entered the oil (IE changed your oil)?
    If it's coming from the head area, then it's more likely to be the head gasket leaking.
    Sorry
