P0457 and the blue connector.
Results 1 to 5 of 5
This is a discussion on P0457 and the blue connector. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; OK, I know what P0457 means, and most of the causes. BUT, while I was checking out my EVAP hoses ...
    Registered User the mike's Avatar
    Dec 2002
    Delran, NJ.
    OK, I know what P0457 means, and most of the causes. BUT, while I was checking out my EVAP hoses I found out that the blue connector has a fitting on the bottom that has a screw in it. Where does this line go? It's the fitting that faces straight down, not front or rear. Looks like 1/8", maybe 3/16".
    The car has a Perrin turbo inlet on it. I do not see any hoses that should be connected to anything. All I need is a location as to where it goes.
    Anyone?
    mike
    Creeping up on creeping for a decade.
    Bugeye Mafia V2 #322
    Aug 2008
    Kennett Square, Pennsylvania
    Which blue connector are we talking about? A pic or general description should help..I don't recall any Blue connector in the EVAP system...
    Dec 2002
    Delran, NJ.
    It's a blue vacuum connector to the left of the alternator. The connector is to the right of the turbo inlet, near the alternator cover. It's the only blue vacuum connector in that area. I'll snap a pic tomorrow.
    (or do a search real quick, BRB)
    Dec 2002
    Delran, NJ.
    The closest I could find real quick.
    http://www.clubwrx.net/forums/1625019-post6.html
    Aug 2008
    Hmm...check the cansister purge solenoid...I have seen alot of times when people install an aftermarket/new turbo inlet that one of the nipples on the caniser purge solenoid break off or crack...
