Results 1 to 8 of 8
This is a discussion on type of spark plugs within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have been reading that for an 02 wrx you can use either the pfr6g or the bkr6eix. which one ...
    Jun 2009
    dover, afb
    type of spark plugs
    i have been reading that for an 02 wrx you can use either the pfr6g or the bkr6eix. which one is better and why?
    Jul 2004
    Seattle, WA
    Spark Plug FAQ: Read if you want spark plug information! - NASIOC
    pfr6g - Platinum
    bkr6eix - Iridium
    Iridium is suppose to last longer.
    Dec 2003
    Dallas, TX / Sterling, VA
    I thought Platinum was supposed to last longer? Either way, I ended up with Coppers after my car rejected the Iridiums I put in them.
    Moderator Donkey's Avatar
    Da boonies
    Iridium has better conductive properties than platinum but not as good as copper. Copper plugs need to be changed 5x more frequently than platinum or iridium.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2004
    Seattle, WA
    Votes for best answer
    Dec 2003
    Yep. But I think they were less than a dollar each.
    Da boonies
    Yeah but I get NGK Iridiums for around $5 each. So for me its worth it not to have to change my plugs every month. Running high boost will kill copper plugs even faster than stock boost levels due to cylinder pressures and heat. Copper is just way to soft.
    2002 FORESTER S
    1998 FORESTER S
