Results 1 to 6 of 6
This is a discussion on Can't shift out of park within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I searched but didn't find anything. My wife's Forrester has a problem shifting the auto tranny out of park. We ...
    SRM
    SRM is offline
    Registered User SRM's Avatar
    Dec 2006
    New England
    My wife's Forrester has a problem shifting the auto tranny out of park. We have to override it by pushing the button next to the shifter.
    I think the faulty part is located in the steering column, because I can hear it clicking while attempting to move the shifter. The problem is intermittent, but getting progressively worse.
    Can anyone tell me what specifically this is? I would like to replace it myself.
    Mine: 2010 Camaro 2SS RS
    Hers: 2010 Wrangler Sahara
    Previous cars: 2000 Z28, 2007 WRX TR
    Not Asian Ying's Avatar
    Jul 2007
    Harrisburg-ish
    So you're able to turn the engine over and freely move the steering wheel correct?
    Could be the brake light switch, solenoid or relay that allows the shifter to release. Also double check the fuses related to brakes or the A/T are blown.
    My guess is the brake light switch
    SRM
    SRM is offline
    Dec 2006
    New England
    Quote Originally Posted by Ying View Post
    Yes.
    I'll check the fuses but as I mentioned, it doesn't happen all the time.
    Can you tell me where the brake light switch and solenoid are located?
    Jul 2007
    Harrisburg-ish
    The brake light switch should be under the dash above the brake pedal.
    I believe the solenoid would be under the housing where the shifter is located. I'll have to check on that though.
    Registered User PurpleMongoose's Avatar
    Jul 2009
    Pittsburgh, PA
    Could be the brake light switch, solenoid or relay...
    Had the same problem on my Audi a few years back. Fortunately, that switch was adjustable via a screw.
    Park where you can see your brake lights. When you can't shift out of park, are the lights on?
    Stink-Eye Mob #666
    2009 WRX Sedan
    SRM
    SRM is offline
    Dec 2006
    New England
    Quote Originally Posted by PurpleMongoose View Post
    Will check this out. thanks!
