serious problem!!!
Results 1 to 6 of 6
This is a discussion on serious problem!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i hace an 02 wrx with 73k, i had a number 4 misfire so i replaced the spark plugs. then ...
    Jun 2009
    dover, afb
    serious problem!!!
    i hace an 02 wrx with 73k, i had a number 4 misfire so i replaced the spark plugs. then it came back and now i have a number 3 and 4 misfire, what is the cause and how much am i going to spend to fix this problem.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by smugglin1986 View Post
    do you have a lightweight flywheel or a lightweight pulley?
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Jun 2009
    dover, afb
    its all stock
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    swap the coils and see if the misfire follows.
    Lead Wrench @ WTF Tuning, LLC
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by LPPTundWRX View Post
    When he says swap the coils he means fully unplug the 1/2 coil's and put them in the place of 3/4, and then put the 3/4's in place of 1/2's... Do a hard reset of the ECU (pull the battery leads off for 30 seconds)
    Then see if the CEL changes or stays the same. It'll rule out whether or not the issue is the coil packs.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Jun 2009
    dover, afb
    thanks for the help
