Weird Noise..
Results 1 to 6 of 6
This is a discussion on Weird Noise.. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok so I just got my timing belt, water pump, alt belt, ac belt, CP idler, and a few gaskets ...
    Registered User Boris22's Avatar
    May 2008
    Weird Noise..
    Ok so I just got my timing belt, water pump, alt belt, ac belt, CP idler, and a few gaskets that go along with the usualy maintenence. Now when I start the car I hear a weird rattling noise. I will hear it then I wont. It also does it when its almost at oper. temp. I was wondering if anyone has had the same noise after this sched maint.
    Could it be the CP Idler? Any help would be appreciated!
    Aug 2008
    Kennett Square, Pennsylvania
    rattling noise huh? like metal on metal?..I would first check that all of your heat shields are properly secured..I'm assuming you have around 105,000 miles fore you just had the t-belt done?
    May 2008
    hmmm...
    I have 94k. And no it almost sounds like something "tapping" the front cover that protects the timing belt and idlers. So like maybe metal on plastic. I would describe it as, when you put regular gas in your car but not as much of a metal sound.... I think it only does it with the heater fan on... not sure I will prob take it and have the place that did it check it out.
    Aug 2008
    Quote Originally Posted by Boris22 View Post
    Good idea, If the noise wasnt there before they did the work and now there is something wrong they should inspect it for free...perhaps they forgot to tighten the lock nut for the AC belt idler pulley and its rubbing on the cover a tad...just thinking out loud here...
    May 2008
    yup!
    Ya I need to get it checked out... Its really cold right now in the Portland OR area so we will see when it warms up... but it didnt do it today at all... I didnt drive it much but I'm really weird about noises on my car!
    Aug 2008
    I hear ya man..I'm the same way with both of my Subies..extremely meticulous when it comes to the mechanical and cosmetic parts of them both.....anyways let us know what they find man...
