Results 1 to 8 of 8
This is a discussion on broken bov?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; as i drive the bov does not open up and when i shift it all gets pushed out like it ...
    Jun 2009
    dover, afb
    broken bov??
    as i drive the bov does not open up and when i shift it all gets pushed out like it being drained out instead of all of the excess air leaving at once. what is the prob my car sounds like ****!!!!
    Aug 2008
    Kennett Square, Pennsylvania
    Is this the stock BPV or is it an aftermarket BOV? If it is aftermarket and your not running over 20-25 PSI my suggestion is to get rid of it and reinstall a stock BPV.. However from what your saying it seems like it might be inproperly adjusted..what kind of BOV do you have? How many miles are on the vehicle? what other modifications are done to the vehicle? Have you done any recent maintaince on the vehicle? Are you having any other driving problems...idle, performance etc etc....
    Jun 2009
    dover, afb
    i have a short ram intake and and aftermarket bov by turbo xs, the car has 72k and it has no problems running or idling and i am not not running over 20 psi. the only recent maintenence was i put in new spark plugs, but it started acting up before i changed them.
    Aug 2008
    Does the noise kind of sound like a flutter like a compressor surge?...So you dont notice ANY performance or driveability problems? Car is hitting target boost?...If this was the case with my vehicle I would install the stock BPV and prob call it a day..
    Jun 2009
    dover, afb
    well the downside is i dont have the stock one and you can tell it flutters a bit when it is not warm
    Moderator Donkey's Avatar
    Da boonies
    If its a hybrid or VTA it probably needs to be cleaned and oiled.
    2002 FORESTER S
    1998 FORESTER S
    Jan 2005
    Eh, whaaaaa?
    If it were me I'd pawn that **** off on someone else and buy a stocker ASAP.
    Cody
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    Ive seen the little vacuum tube get pinched also and it stops making the annoying noise.
    Lead Wrench @ WTF Tuning, LLC
