You have two separate issues.
The overflow from the radiator cap, if there is one, and from the turbo coolant reservoir should be tee'd after both caps so that they join to one line that goes to the overflow reservoir. Also, the system needs to be burped, as you may have air pockets. Burp the system.
As for the fuse, did you reconnect the harness correctly?
LinkBack URL
About LinkBacks
